Need junkyard 5.0 build recipe...
Old November 16th, 2010, 10:24 PM   #1
444
444 is on a distinguished road
Hi all, I just found this forum and hope this is a good place to get some solid tech info. I'm a mopar guy but I've always liked some of the Ford stuff and this will be my first ford build, so forgive me I don't have any ford specific tech knowledge going into this.
What I've got is a car with no motor/trans and I've got a local u-pull yard with a decent variety of late 80's/early 90's 5.0 mustangs and trucks. I want to keep this build simple so carb and mechanical distributor, no efi. What I'd really like to know is what years of blocks and heads should I be looking for and what years should I stay away from? I figure I might as well pick out the best years of the available junkyard stuff I can find. What I would like to do is find a 5.0 with a decent bottom end, with a set of factory heads of which ever year(s) is best then do cam, intake/carb and headers, gaskets, valve springs, timing chain, etc and run it. Basically your typical budget mild street bolt-on build. I would be real happy if I could I get 275hp and 350ft-lbs out of it. Not looking to build a ground pounder here.
What should I start looking for?
Old November 16th, 2010, 10:31 PM   #2
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
go find a 5.0 explorer or mountaineer
Old November 16th, 2010, 10:43 PM   #3
444
What years of explorer? I thought all the early 90's ones were the 4.0 v6's? My buddy used to have one and I don't remember ever seeing one with a v8?
Edit: Just checked and wikipedia says 1996+. That may be a bit new for me to find at the junkyard I usually go to but I will keep my eyes open. If I can't find one of those, what would my second best choice be?
Old November 17th, 2010, 01:03 AM   #4
ryanw's Avatar
1991 Ford Mustang GT
are you going to pull it all apart and stuff the block will all new stuff or are you just going to drop it into a car as is ? if your going to drop it into the car as is id stay away from 1986 mustang 5.0 they had crappy pistons and heads. if your only looking to get about 275 hp almost any block will work. but 1987-1992 5.0 have 225 hp 300 fpt with forged pistons and they have roller cam. 1985 has 210 hp roller motor last year of carb, 1986 200 hp first year of efi. 1993 225 hp no forged pistion All these are numbers on mustangs i dont have a clue when it come to other ford engines
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 17th, 2010, 01:22 AM   #5
444
Yes I am hoping to find one with a decent bottom end that I can just drop in. I'm already in the middle of a motor rebuild for another car and don't really want to spend a ton of cash on this one. Are 87-93 all the same heads?
Old November 17th, 2010, 01:32 AM   #6
ryanw's Avatar
as far as i know YES. E7 heads you can get GT40 heads off of an ford explorer not sure what years though they flow better and have a smaller combustion chamber. also if you look up 1993 mustang 5.0 it said they have 205 hp but in 1993, Ford switched to cast hypereutectic pistons for all 302 cu in engines and also re-rated the 5.0 GT at 205 hp and 275 ft·lb of torque. This estimate was more accurate because the previous power ratings were made before the addition of the mass air flow system, a minor revision in the cam, and other various changes. but they really still had 225 hp
255 fuel pump,
3:27 gears
Old November 17th, 2010, 01:38 AM   #7
ryanw's Avatar
Okay i think the V8 explorers with gt40 heads are 1996-2001
255 fuel pump,
3:27 gears
Old November 17th, 2010, 08:15 AM   #8
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
96-early 97 had GT40(3 hash marks on the front of the head) 97.5 -01/02? had the GT-40p heads(4 hash marks on the front of the head)
I would start with a nice used Explorer 5.0, add a cam, valve springs, intake, exhaust, etc. and you will be close if not over 300 HP!
If you can find a lower milage one, you wouldn't even have to rebuild. They are a pretty stout engine!
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old November 17th, 2010, 02:53 PM   #9
95StangMX's Avatar
95 Mustang GT
Keep in mind all of these HP ratings everyone is throwing out are not to the shoes, those numbers are all to the crank.
and why go carbed if you can just pick up a whole exploder motor and change the cam, intakes, springs, and a few other simple boltons you will have a pretty stout little engine and not have to worry about cold starts and stinking like gas every time you drive it.
Think about it buddy girls don't like to go out to dinner or a movie and get all fixed up, to smell like gas the entire evening....
Old November 17th, 2010, 03:17 PM   #10
444
Okay well at least now I have a decent idea what to look for. I was aware these are crankshaft HP numbers.
Have you ever driven a vehicle with a well tuned carb and correctly dialed in automatic choke? Driveability and cold-starts are not even an issue once it's setup properly. But FWIW I'm in the process of a carb->efi conversion on my other car and this one I just want to keep simple.
Old November 17th, 2010, 03:20 PM   #11
95StangMX's Avatar
95 Mustang GT
You ever driven a well tuned efi car? they have no problems with cold starts, get better MPG, and don't stink... haha its your car man, do what you feel confortable with I am better with fuel injection than dialing in a carb so ...... but good luck and post up some pics and progress....
EDIT: What year is the rolling chassis you are building? Post up some pics of the project as it is now and you can make this your build thread and continue to add pics and progress of your work...
Old November 17th, 2010, 05:14 PM   #12
91cobra5.0's Avatar
98 Cobra
Do you have a set budget? Craigslist and internet forums can net u some really nice parts for just as cheap as a junkyard and there is a lot wider of a variety of things for u to choose from
Old November 17th, 2010, 05:49 PM   #13
Smirnoff's Avatar
1982 GT t-top
hmmmm weird i dont smell like gas every time i drive my car and it starts right up in the cold with no choke
Old November 17th, 2010, 06:18 PM   #14
444
I did have a look at the local classified websites and couldn't find much. The local u-pull will sell me a complete 5.0 for $200 w/ a 90 day warranty.
Old November 17th, 2010, 06:27 PM   #15
Smirnoff's Avatar
1982 GT t-top
^ thats not a bad deal at all
Old November 17th, 2010, 07:32 PM   #16
91cobra5.0's Avatar
98 Cobra
Old November 17th, 2010, 07:56 PM   #17
A complete 5.0 out of a what?? 5.0's come in different forms. 87-92 5.0 HO would be the best short block to start with.
01 Ram Quad Cab
03 Grizzley 660
Old November 17th, 2010, 07:58 PM   #18
ryanw's Avatar
ya you want a H.O 5.0 the hp is way different between the two
255 fuel pump,
3:27 gears
Old November 17th, 2010, 11:19 PM   #19
Actually the 87-92 HO's came with TRW forged pistons, nothing to do with HP, just way stronger than your average Crown Vic/F150 5.0!!!!!!!!!!!!!
01 Ram Quad Cab
03 Grizzley 660
Old November 18th, 2010, 12:35 AM   #20
ryanw's Avatar
Ya i know. did i say some thing that made it seem like i thought the type of pistons made one motor more powerful then another. i was just pointing out that a 302ci (5.0) high out put made more HP then the standard 302 (5.0) non high out put. wich was 1985 and before. like in 1985 the difference in HP between a high out ( HO) and non H0 was 45 HP.....http://fox-body.com/
255 fuel pump,
3:27 gears
Threads Similar to: Need junkyard 5.0 build recipe...
Recipe Help Cricket The Clubhouse 5 October 4th, 2010 12:06 PM
Recipe for a 350 RWHP NA 2V acmillr 99-04 172 October 16th, 2009 03:57 PM
A True junkyard Build.....Crazy stroked93 Videos 12 May 27th, 2009 03:06 AM
hang over recipe Trance The Clubhouse 15 March 28th, 2008 01:19 PM
My Special Recipe :) TheUNZippee! The Clubhouse 30 November 3rd, 2007 01:46 PM
