1989 LX
12.60 at 109mph
Novi vacuum questions?
okay so i was reading on the novi installation guide and it says for the FMU that it needs to be Teed off to the FPR and to the intake. Right now it goes from the vacuum tree to the top of the FMU. but on another website it says how it is set up right now is correct. i dont know should i just try it the other way and tee the lines and see what happens? the car right now runs decent but after giving it full throttle the car sputters and hickups and i have to turn it off the back on then it runs completely normal like it was never there.
1989 LX mustang, 5speed, 108,xxx miles, Mac Longtubes, BBK midpipe, Paxton Novi 1000 6psi, Crappy FMU with 19lb injectors, 373 gears soon to come 30lb injectors, Blow through MAF, intercooler and tune |
1991 Ford Mustang GT
make sure you disconect the hose that goes from yout oil filler neck to your TB. you dont want to blow any boost into your crank case. either run a breather in place of your filler cap or just run a longer hose from your filler cap to your air filter box. make sure no matter what that you plug the line coming off your TB...... But as far as your question sorry dont know
1989 LX
12.60 at 109mph
yea i already got it plugged at the throttle body and it does go to the airbox already and i have a breather where the rear PCV goes because it was blowing oil out the back BAD!!!
1993 5.ohhhh
12.97 @140mph
I can't remember how an fmu works, but I think the way the guide says is correct. Both the frp and that need to see boost I believe.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
The FPR line is the good place to T but just about any vacuum line will work. My FPR goes to the manifold and so does my FPR. As for oil blowing out the PCV, do a compression check for an idea of what's going on in there. I run 12psi and my PCV blows no oil.
1992 Lx
11.39@119.24
remember when your wheel fell off?
1993 5.ohhhh
12.97 @140mph
Like I said, I'm going to go drive my car later. Should be fun reg.
1992 Lx
11.39@119.24
rotfl reg. Put the vacuum lines a lil different on this paxton pos and the drivabilitys better, still hiccups sometimes but he also has a stock fuel pump lawlz
1993 5.ohhhh
12.97 @140mph
Good to hear, could be the stock pump, but I doubt the car makes more then 250 at the wheels. Needs pulley...
1992 Lx
11.39@119.24
scared to run it on the stock headgaskets and bolts lolz
1993 5.ohhhh
12.97 @140mph
255 lmaf and a pulley with some 42lbers. Iron heads don't lift homeboy
1992 Lx
11.39@119.24
2006 GT
11.99@114
Damn son, you mad?
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
fmu = you have a small penis
1992 Lx
11.39@119.24
Member when your wheel fell off? That cars gona be a fuckin stroker killer when its done. Shooting for 900whp
1991 Mustang LX 5.0
What the hell is up with his wheel falling off?
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1992 Lx
11.39@119.24
Just me talking shit to him since I have a crush on him. Its how I flirt <3
Threads Similar to: Novi vacuum questions?
| Zex install, vacuum line questions | 91blkgt | 5.0 Mustangs | 2 | June 7th, 2010 06:50 PM |
| novi 2200 | flattusmaximus78 | 2005 - 2010 | 5 | September 7th, 2008 04:15 PM |
| Questions on vacuum set up on Explorer intake?? | MonsterSD | 5.0 Mustangs | 1 | August 17th, 2008 10:47 AM |
| Novi 1200 tuner kit questions | tribaltek | 2005 - 2010 | 31 | June 28th, 2008 02:16 PM |
| the novi Sl | SEANMD81 | 2005 - 2010 | 6 | August 29th, 2007 01:58 PM |
