got back from the dyno
Old November 17th, 2010, 09:07 PM   #1
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
b-on-b 5.0 is on a distinguished road
car dynoed 563.6rwhp and 550.5 rwtq at 5,500 rpms @9.5 psi then ran out of fuel....reline of the motor is 6,500-6,800 rpms so it gives me roughly 1,000rpms to 1,300rpms to play with till redline and idk how much more boost..should be in the 600,s by 6,500rpms
Old setup
93 cobra motor, supporting mods, 11.5psi out of
V3 S-Trim made 422.5rwhp and 450 rwtq
ran 12's at 5800 ft above sealevel
new setup 347 on 11psi made 616.9rwhp and
576.0rwtq
Old November 17th, 2010, 09:10 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
Thats nice. what do you think your HP is at the fly wheel 620 or so?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 17th, 2010, 09:11 PM   #3
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Nice numbers. What block do you have?
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old November 17th, 2010, 09:52 PM   #4
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Corrected?
Old November 18th, 2010, 12:36 AM   #5
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
i REALLY hope its not the stock block.
even corrected numbers still has you at that risk zone for a oem block.
sick numbers though, more then I expected with that boost level.
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old November 18th, 2010, 08:54 AM   #6
orangestang42's Avatar
1995 Mustang GT
orangestang42 is on a distinguished road
incredible numbers, just shows me why i love mustangs...
Old November 18th, 2010, 09:10 AM   #7
'11BlackWidow's Avatar
2011 Mustang GT C/S
'11BlackWidow is on a distinguished road
Send a message via AIM to '11BlackWidow Send a message via Skype™ to '11BlackWidow
Great number man. Gota love a high Hp Fox body
TAMPA BAY AREA CREW
MILITARY CREW
Black Stang Crew
2011 Mustang GT/CS: Blk on Blk
Bassani Lng Tube Hdrs w/ High Flow Cats & 3" Stnls Catback Exhst, JLT Carbon Fiber CAI, SCT Tuner w/ BAMA Tune, Boss 302 Frnt Splitter, Smoked Tail & Side Mrkr Lghts
Old November 18th, 2010, 09:11 AM   #8
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
no corrected to my elevation of 5,800ft above sea level the numbers were ike 457rwhp up here but like i said by redline should be close to 600rwhp or over for sae numbers and corrected would be about 500rwhp for my elevation
Old setup
576.0rwtq
Old November 18th, 2010, 10:54 AM   #9
nolife's Avatar
91GT, 88GT, 02GT
I don't know what equations you are using for correction and not that a final number really matters to anyone anyway but for your planning purposes... As your boost goes up, the value of the correction factor that needs to be applied for a realistic output power estimate for the elevation difference goes down. Meaning.. The higher the boost the lower the effect of altitude. The ratio of pressure difference goes down, that is the reason why using boost in higher altitudes is so popular.
Old November 18th, 2010, 10:59 AM   #10
Trick Tuners's Avatar
KB'd GT
Nice numbers!
Old November 18th, 2010, 11:02 AM   #11
1992 Lx
11.39@119.24
I lawl at corrected numbers. Your car makes 457. Be happy you dont need to tell people it makes 600
Old November 18th, 2010, 11:27 AM   #12
WhiteMamba's Avatar
88 Notch
WhiteMamba is on a distinguished road
what did it run at the track? what is your trap speed?
88 Notchy
306 with 70mm Turbo
510 RWHP on 10lbs
K thnx
Can we chat?
Old November 18th, 2010, 01:46 PM   #13
302Army187's Avatar
'89 LX 'Vert
+1
I estimate a N/A car loses 18-19% HP from our elevation. a boosted car probably only loses half of that, and at higher boost levels a 1/4.
I would guess 560whp with 9.5% loss for elevation puts you around 510-520whp. but my figures are probably way off.
I know my n/a numbers are good, but for boost im not sure.
Old November 18th, 2010, 02:44 PM   #14
1992 Lx
11.39@119.24
jesus horse on emu porn christ that made me lol
Old November 18th, 2010, 08:30 PM   #15
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
yea no i was just posting the sea level numbers cuz half the people around here dont understand that elevation affects hp and go off what sea level numbers are sothats what i posted and when u go to a dyno up here all they give u is the sae numbers so easy dont freak 93hatch
and track times idk yet still waiting for it to open
the 600 number is a guestamiate for SEA LEVEL (sae numbers) when i can get fuel and take the motor past 5,500 rpms
Old setup
576.0rwtq
Threads Similar to: got back from the dyno
Just got back from the dyno b-on-b 5.0 5.0 Mustangs 10 May 11th, 2010 05:04 AM
Got back from dyno Jaygt 99-04 12 April 14th, 2010 08:56 PM
just came back from the dyno unblock 99-04 61 November 24th, 2009 01:55 AM
back from the dyno.... MineralGreyGT 99-04 12 April 27th, 2008 11:31 PM
Back From The Dyno mdvaldosta 99-04 15 February 16th, 2007 11:56 PM
