Identify a relay in engine compartment
There is an electrical relay mounted on the passenger side fender well on a metal tab, just under and slightly behind where the stock MA meter would be. Its wires travel around the strut tower and into a bigger pack of wires. Any idea what that relay is for?
I have one of these relays on my 91 and my 88. My 88's wiring for this relay is all chewed up and corroded so I am wondering what is not working because of it and if I should replace the wiring.
that should be your a/c comp relay
Thanks.
I was now able to find it in the Haynes manual. It disengages the A/C clutch at WOT. I'll verify if my compressor engages or not and fix as required
should be a fuel pump relay
Yes it is the A/C relay you are talking about. And just a little FYI in late 92 and 93 Ford did decide to move the fuel pump relay into the engine bay in the same area as the A/C relay, but until then it was under the driver seat.
the relay on the metal tab in front of the strut tower in the engine compartment is the fuel pump relay!!!
#8 | |
that 86 has a 91 Gt wiring harness in it!!! and the 86 is under the drivers seat!!!
look on this diagram, its showing a fuel pump relay. check the colors to make sure http://www.veryuseful.com/mustang/te...ng_Diagram.gif
91 Gt Convertible RNH Perfomance 331 dart stroker w s-trim dart stroker with s-trim, 91 vert
Threads Similar to: Identify a relay in engine compartment
| could anyone identify this: | kit | Classic Mustangs | 22 | September 26th, 2007 02:06 PM |
| How to Identify 351 From 302 | GTXRacing | 5.0 Mustangs | 30 | March 27th, 2007 02:18 PM |
| Engine compartment... | singe | 99-04 | 9 | March 11th, 2007 12:49 PM |
| Engine Compartment | singe | V6 Mustangs | 10 | March 11th, 2007 12:54 AM |
| Engine Compartment | chase | 5.0 Mustangs | 7 | February 12th, 2007 12:00 AM |
