Nitrous Question
i'm only going to run a 100-150 shot, but i'm going to start with a fifty shot just to get the engine used to it.i have a question what is the stock timing set at and how much should i retard the timing
The engine doesn't get used to it. Starting with a smaller amount won't make anything last longer. In all honesty, 150hp is a small amount of nitrous. Stock initial timing is 10 degrees btdc. Most people run 14-16 degrees btdc. With 100hp of nitrous you don't need to retard any timing. Just run 92 or higher octane fuel. With 150hp I'd pull 2 degrees out.
'88 LX body '91 GT D/T
8.7 in the 1/8th
Will the factory fuel system be able to handle that much? Also, what about the spark plugs? Should he drop 1or2 steps colder?
These are questions I think need to be answered... For me and 351...
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
#4 | |
#5 | |
well i'm running a wet kit and my timing is get at 16 deg advanced if i run a 150 shot do i go back to 10 deg or do i go less
#7 | |
Wet kit or not doesn't matter, I would upgrade the fuel system. Like I said in my previous post pull 2 degrees out with 150hp which would put your initial timing at 14 degrees instead of 16 degrees.
I HAVE A 255 IN THE TANK I CAN HEAR THAT DAMN THING INSIDE THE CAR
BUT AS ALWAYS THANKS FOR YOUR INFO IT HELPS ME OUT ALOT THANKS MAN
El Conquistador
what about a carburated car, i have a holly mech pump that does 80gph, what would i need to do for nos
#10 | |
1990 LX hatch
El Conquistador
i have a 650 demon on it and i have a gauge and its in the 6-9lbs area,the carb needs more fine tuning before i add it though
Threads Similar to: Nitrous Question
| nitrous question | BWAL | 5.0 Mustangs | 26 | November 2nd, 2007 06:49 AM |
| Nitrous question | 89LX347 | 5.0 Mustangs | 25 | July 2nd, 2007 02:19 PM |
| nitrous jet question | flattusmaximus78 | V6 Mustangs | 13 | May 17th, 2007 11:12 PM |
| Another nitrous question | ByPopularDemand | V6 Mustangs | 24 | April 13th, 2007 02:29 AM |
| Another Nitrous Question | keiken | 96-98 | 7 | March 2nd, 2007 10:05 AM |
