Brightest Headlights - Page 2
Old November 24th, 2010, 04:55 PM   #21
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Originally Posted by centipede3001 View Post
Hes right and sorry i dont like halo headlights i think they are for tuners
+1
Old November 24th, 2010, 06:55 PM   #22
1988 Mustang GT
13.5@102
PureEnergi is on a distinguished road
as a straight bulb upgrade...GE nighthawks work well and last considerably longer than a silverstar ultra.
personally id buy an hid kit. www.intensehid.com is who i use. good ballasts with a decent warranty that wont break the bank. buy the relay harness!! i run the magnetic servo versions (bi-zenon) so i didnt have to change my headlights and i retain hi and low beam in one bulb. power comes directly from the battery if you buy the relay harness which i strongly suggest. 6000k i what i run they look good and you can see like its daytime. bi zenon setup they sell is a very nice kit<< on sale now.. 139$ plug and burn
Old November 24th, 2010, 08:45 PM   #23
EscortSportage's Avatar
1989 Mustang GT 5.0
time for HIDS, 6k or 8k
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old November 24th, 2010, 11:31 PM   #24
moneymo's Avatar
1991 Mustang Gt 5.0
moneymo is on a distinguished road
Do the HID kit.. I have the bixennon kit with a relay switch. My low beams still blind folks, but i can see "clearly now, the rain is gone."lol. I say go that route, its a easier way to upgrade your old lights.
91 Mustang Gt
306/Under Drive Pulleys/gt40 heads/ so many more goodies
Old November 24th, 2010, 11:35 PM   #25
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
Get a eBay hid kit for under $40. At work we sell the same kind. Hids make a big difference even in the foggiest headlights.
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old November 25th, 2010, 12:08 AM   #26
centipede3001 is on a distinguished road
ok thanks guys im definitely gonna go with that because it will be a lot cheaper then trying to find a set of bulbs that are brighter
Old November 25th, 2010, 12:17 AM   #27
does anyone know off hang what the bulb size is on a 1994 mustang ?
Old November 25th, 2010, 12:22 AM   #28
never ind i found it out its 9007
Old November 25th, 2010, 11:04 AM   #29
1989 Mustang GT 5.0
after putting HIDS on both my cars, i will never use halogen again
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old November 25th, 2010, 11:07 AM   #30
moneymo's Avatar
1991 Mustang Gt 5.0
I say get the Bixennon kit. I just installed mine with its own relay and everything, and man o man are they bright. Im running 10K on headlights and fog lights, at night on low beams its daylight anywhere my car runs i promise..lol. Thats with the lights tinted. Thats the best i can help with, cause ive done the same.
91 Mustang Gt
Old November 25th, 2010, 01:51 PM   #31
fogged306's Avatar
89 GT
I used to work at a place that sold and installed the cheap ebay style HID kits. Almost every one came back with either blown bulbs or dead ballasts. probably 30% or better had something bad right out of the box. I would never go cheap on an HID kit for that reason. I also had problems with the slim ballasts in my car. They wouldn't start the bulb at random when I would turn my lights on and I would have to turn them off and back on as many times as it took to get the bulb lit.
Also, if you're looking for the brightest light I believe 5300k is the temp that puts out the most lumens. I may be off by a few hundred degrees of temp on that but it's somewhere in there. The hotter you go in bulb temp, the less light the bulb actually puts out, but the more "exotic" the color. Meaning 5300k is pure white and the brightest and 10000k is purple or pink but not nearly as bright.
Old November 25th, 2010, 02:03 PM   #32
moneymo's Avatar
1991 Mustang Gt 5.0
Ha ha very true indeed.!!
91 Mustang Gt
Old December 6th, 2010, 01:15 PM   #33
Predator's Avatar
1993 Mustang GT 5.0
Predator is on a distinguished road
The question I have is this... I just bought the 1993 GT 5.0 the Guy I bought the car from had the one piece head light installed in the car the I'm having the same problem in the car my headlights are extremely dim if I install the wiring harness in the lights there bright but they are melting the harness. Are the 9007 the right lights for the 1993? Wasn't wanting to install HIDs just yet
Old December 6th, 2010, 07:07 PM   #34
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
Originally Posted by bigjohnstud4200 View Post
are your headlights smoked by vht / tint or did you buy them smoked? are they heat beaten? If so, you can sand them, redo the tint and clear coat and be much brighter.
I always thought about that what kind of grit sand paper would you use?
Old December 6th, 2010, 09:19 PM   #35
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
Depends on how bad the yellowing is and if you are doing it by hand or machine. I used 400 grit (fairly rough) to get rid of my yellowing, which was pretty bad. Then I went to 600, then 800, then 1000, then i polished using an adapter on my drill (that was the first light).
That took forever, so then I used my pnematic 6" polisher and did 400, then 800 then 1500 which took less than a third of the time.
Warning though, even after the 1500 grit, the lights looked pretty rough and DEFINITELY not clear. I was a little worried but I still VHT'd them and then when I put the clear coat on, crystal clear. I also used automotive clear, but when I did my third brake light a month or so later I just used rattle can clear and it looked good too, not as good, but definitely good.
Good luck.
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old December 7th, 2010, 12:19 AM   #36
moneymo's Avatar
1991 Mustang Gt 5.0
1+
91 Mustang Gt
Old December 7th, 2010, 01:58 PM   #37
PONYMAN's Avatar
PONYMAN is on a distinguished road
Send a message via Yahoo to PONYMAN
Smile
I bought new lens kit from 5.0 Restro & they were nice [ the clear ones ] parking lens too.
Here in Texas ,fi you park your car outside , the sun does some real damge on the lens.
There is some lens cleaner you can get at Chief Auto Parts that works quite well ,if used reguarly.
Have you driven a Ford lately ?
Threads Similar to: Brightest Headlights
Headlights! DONE with ebay headlights!!! Saleen0101 Modular Mustangs 11 December 30th, 2010 02:18 PM
converting my 85 LX headlights to the later model fox body headlights pd411 General Car Care & Detailing 0 January 11th, 2010 10:53 PM
projector headlights vs regular headlights BossOfDaRich V6 Mustangs 7 June 22nd, 2009 09:57 PM
Headlights As Well? 96GtGoodz 96-98 4 November 17th, 2007 08:31 PM
New Headlights graystang01 Visual 3 November 12th, 2007 08:50 AM
