Maf/tb questions
Old November 25th, 2010, 05:18 PM   #1
92ponylx's Avatar
92 Lx
Slow
92ponylx is on a distinguished road
Maf/tb questions
ok i have a C&L 75mm maf and im thinkin of buyin a 75mm tb from professional products... my question is are they shitty products or are they decent. once again thank you for your help guys...
Old November 25th, 2010, 05:20 PM   #2
EscortSportage's Avatar
1989 Mustang GT 5.0
i have a 70mm tb and egr from pro products, havnt tested it yet, but it looks legit, a friend has same one running 12.00 with 200,000+ miles on the motor, he loves it,
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old November 25th, 2010, 08:19 PM   #3
1992 Lx
11.39@119.24
as long as it doesnt stick run it. Most intakes wont be 75mm wide at the opening though
Old November 26th, 2010, 08:12 PM   #4
92ponylx's Avatar
92 Lx
Slow
HATCH.... whatcha mean
Old November 26th, 2010, 08:58 PM   #5
1992 Lx
11.39@119.24
what intake is on your car
Old November 27th, 2010, 03:12 AM   #6
92ponylx's Avatar
92 Lx
Slow
the guy has a half ass build your own cai im gonna be buyin a bbk cai... not the fender mount one
Old November 27th, 2010, 09:27 AM   #7
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Oh, so you're going to be buying a new 'warm' air kit.... lol
Anywho, Hatch is talking about your intake on your motor. Is it the stock one, or TrickFlow, Edelbrock, Holley, Professional Products, etc. ???
Also, the Professional Products Throttlebody's' had an issue that I read about once about them being 'sticky' off idle, or sticking closed and requiring a greater effort to get it to initially open.
Old November 27th, 2010, 02:44 PM   #8
92ponylx's Avatar
92 Lx
Slow
I have no choice with the cai. I don't have inner fenders. And yeah stock intake. And what do you mean stick. What should I get. I have 24lb injectors and a 75mm maf. Just lookin at doin cai, Maf, tb, injectors, and then a chip from alternative
Old November 27th, 2010, 02:50 PM   #9
1992 Lx
11.39@119.24
stock intake doesnt open up to 75mm so the tb would be a waste of money
Old November 27th, 2010, 02:54 PM   #10
ryanw's Avatar
1991 Ford Mustang GT
Are you going to port your upper intake plennum opening to the same size as you new TB ? if you dont and you put a 75mm TB on an intake that only has a 60mm opening your not really doing any thing with a bigger TB. Get an accufab TB there great. And when you said that you dont have inner fenders are you saying that you removed the plastic fender wells ? And if thats what you did WHY?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 27th, 2010, 03:14 PM   #11
92ponylx's Avatar
92 Lx
Slow
Well what tb should I get then seein how I have the 24lb inj and the75mm Maf that came withe the cAr but nit installed... And the previous owner lower it 2inches so he removed the inner fenders so it wouldnt rub but it still does
Old November 27th, 2010, 03:18 PM   #12
ryanw's Avatar
just pull your intake off and port it to the same size at your TB. On my car i have a 75mm mass air and a 70mm TB 24lb injectors
255 fuel pump,
3:27 gears
Old November 27th, 2010, 03:22 PM   #13
92ponylx's Avatar
92 Lx
Slow
Do you have stock intake cause I do... And did you notice a big up differencep
Old November 27th, 2010, 03:24 PM   #14
92ponylx's Avatar
92 Lx
Slow
My bad did you notice a big hp diff... I'm doin all this off my iPod damn spell correct
Old November 27th, 2010, 03:26 PM   #15
ryanw's Avatar
I have a cobra intake but the intake opening i think was only 65mm so i still had to port it to 70mm. but if you port your stock intake to 70mm your going to need to get a 70mm EGR there only 50 bucks. a cobra intake has the EGR built into the intake so i didnt have to buy one
255 fuel pump,
3:27 gears
Old November 27th, 2010, 03:32 PM   #16
92ponylx's Avatar
92 Lx
Slow
The bbk tb I wAs lookin at comes with the same size egr also. It's a kit I was lookin at American muscle. Do you think All of that will wake it up? Cai,Maf,tb,inj, and sct tune
Old November 27th, 2010, 03:36 PM   #17
ryanw's Avatar
A little... your heads are a choke point. it you have the money to get cylinder heads at the same time you will notice a big difference.
255 fuel pump,
3:27 gears
Old November 27th, 2010, 03:37 PM   #18
ryanw's Avatar
you really dont need 24lb injectors with the modds you have. your stock injectors are good from 280-300 HP now if you get after market heads then you will need 24lb injectors
255 fuel pump,
3:27 gears
Old November 27th, 2010, 03:42 PM   #19
92ponylx's Avatar
92 Lx
Slow
Will I get a gain with the injectors or will I mess shit up buy putting them on there...
Old November 27th, 2010, 03:45 PM   #20
ryanw's Avatar
you will not get any sort of a gain with bigger injectors. you only get bigger injectors when you system needs more fuel. if you go to big it can mess things up
255 fuel pump,
3:27 gears
Threads Similar to: Maf/tb questions
MAF questions WLJohnson05 V6 Mustangs 11 April 10th, 2010 05:36 PM
maf questions gotn20 5.0 Mustangs 7 April 1st, 2009 05:17 PM
MAF and Injector questions kpoirot 94-95 9 February 1st, 2008 06:32 PM
MAF Questions ThreeHonks302 5.0 Mustangs 20 January 27th, 2008 07:50 PM
MAF questions ? Smoph 5.0 Mustangs 3 May 11th, 2007 10:43 PM
