engine oil
Old November 27th, 2010, 08:59 AM   #1
1990 ford mustang GT
bennyjet846 is on a distinguished road
engine oil
just curious, what engine oil do u guys use/prefer? i use the 5w30 fully synthetic Valvoline oil. was thinking of switching to royal purple but that shit is so expensive.
Old November 27th, 2010, 09:10 AM   #2
nolife's Avatar
91GT, 88GT, 02GT
Normally Motorcraft synthetic blend 5w20 and a FL1-A filter from Wal-mart, 5qts bottles are $13-14 and $3-4 for the filter. No particular reason why other than its cheap. Other than that, I buy whatever oil and filter "oil change" combo deal is on sale at auto parts stores and whatever viscosity I feel like at the time. The only thing I avoid is the Fram oil filters based on some past information I've seen from people that cut them apart and analysed them. That information may be outdated and the Fram design may have changed but I still avoid them.
Oil choice is a like religion. I have no religious preference
Old November 27th, 2010, 09:13 AM   #3
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
amsoil....simply the best...do your homework...google it..it might be expensive but so is an engine...call it insurance
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
Old November 27th, 2010, 09:21 AM   #4
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
If you're not running any serious power, there's not reason to run anything more than what you mentioned in your post. Amsoil and RP is just for different applications IMO. How many 100K miles engines we know of running regular Kendall and Valvoline crap, too many to list.
Having said that, I run Mobil 1. I will test the oil after my motor is completed, dynoed and ran for a week or so, to see how the oil holds up on 750+ HP.
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old November 27th, 2010, 09:45 AM   #5
FastStang91Lx's Avatar
1991 Mustang LX 5.0
I run full Synthetic Valvoline 10-30 but my motor only has 5-10k on it, and for a filter... Almost anything but Fram for same said reason. Our dd's with higher mileage get the 'high milelage' valvoline syn blend because the leak too much oil if I run full syn. The molecules of synthetic are smaller so therefore will show more leaks. I thought it was bullshit myth stuff, but it's actually true.
Old November 27th, 2010, 10:06 AM   #6
1992 Lx
11.39@119.24
10-30 dino oil
Old November 27th, 2010, 11:57 AM   #7
selbyvince's Avatar
1991 ford mustang lx 5.0
12.1@114
selbyvince is on a distinguished road
i run the 10w30 royal purple in my car. 9k miles on my motor and i have a lil over 400hp. although its expensive, like the guy up top said.. way cheaper than a motor, and i do agree it depends on the application, factory motor probably wouldnt be the ideal use for it, but it wont hurt it either!
Old November 27th, 2010, 04:59 PM   #8
Dap1991's Avatar
91 GT 90 LX 5.0
Dap1991 is on a distinguished road
so fram is a bad filter? lol i have been using that on my explorer and lx the past few changes cause it has that convinient little hand grip, guess it times to switch
1991 GT- All Stock
1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs
Old November 27th, 2010, 05:43 PM   #9
2000 gt
ford specifies 5w29....due to the very tight tolerances in the 4.6 modular engine...if you follow the 3000 mile drain interval i am sure it really doesnt matter what you use....amsoil for me simply because i am a preferred customer and get it wholesale
Crew Member # 3
Old November 27th, 2010, 07:37 PM   #10
wow i learned something faststang. should i go down to regular 5w30?
Old November 27th, 2010, 09:39 PM   #11
2000 gt
5w20 oops.... Typo
Crew Member # 3
Old November 27th, 2010, 09:47 PM   #12
nolife's Avatar
91GT, 88GT, 02GT
Originally Posted by Everett View Post
5w20 oops.... Typo
I was looking for 5w29
Fords (and some others like Honda) decided to switch to 5w20 as a "universal oil" back in 2001-2003. MPG and CAFE standards were a consideration for the change. How much of the decision was based on MPG and how much was based on engine protection is still a controversy. Some cars went from a 10w30/5w30 suggested to a 5w20 suggested oil the next model year even with no engine changes. Ford even suggested some older cars that had other oils suggested in the owners manual should be switched to 5w20 as well as seen with this TSB (full TSB PDF here).
This was a huge controversy in forums back in the 2002 time frame when it happened and still argued today.
A google search for +Ford +decision +5w20 +CAFE will give you an idea of what was being discussed.
Ford published some letters later to defend the decision like this one. https://www.fleet.ford.com/FFH/Why5W...sp?News=Rental
Old November 27th, 2010, 10:40 PM   #13
EscortSportage's Avatar
1989 Mustang GT 5.0
10 30 royal purple
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old November 28th, 2010, 01:21 AM   #14
Firaga's Avatar
1993 Mustang GT
Firaga is on a distinguished road
Depends what's on sale. If I can find the 5-quart bottles of Castrol high mileage 10w30 then I go with that. If not, 5w30 or whatever I can find in the 5 quarts that's cheap.
I guess I shouldn't buy Fram anymore after hearing what you guys say. At O'Reilly all they sell is Fram or K&N... eh
For those who are smart:
The car seems to run fine with whatever I put in it, is it bad to switch between the two?
I have a 93 5.0
I love my car, and all my friends hate it.
AEM Brute Force intake, BBK 75mm TB/EGR, C&L 75mm MAF, Trick Flow Street Upper/Lower, Custom exhaust with Dynomax SuperTurbos, Tokico Rear Shocks
Old December 1st, 2010, 08:29 PM   #15
hfjeff's Avatar
1993 Mustang LX
hfjeff is on a distinguished road
I run full synthetic NAPA 10w30 with Napa Gold filter. I am friends with the local owner and he told me it was made by Valvoline. Usually can catch it on sale for $3.29 qt.
Old December 1st, 2010, 10:14 PM   #16
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
i'm a valvoline full syn guy or mobile one for a filter you will never go wrong with a wix filter
Old December 2nd, 2010, 03:16 AM   #17
moneymo's Avatar
1991 Mustang Gt 5.0
moneymo is on a distinguished road
Mobile 1
91 Mustang Gt
306/Under Drive Pulleys/gt40 heads/ so many more goodies
Old December 2nd, 2010, 03:45 AM   #18
i guess what fram put on their box is bullshit? they have these "extra guard" that supposedly filters a lot better than other oil filters. i bought into that hype.
Old December 2nd, 2010, 09:04 AM   #19
fram sucks
mobile 1 in the turbo gm's
rotella in the turbo fox
anything but pensoil in the daily driver fox
Old December 2nd, 2010, 01:10 PM   #20
nolife's Avatar
91GT, 88GT, 02GT
The extra guard are different then the regular ones. The issue in the past was poor gluing on the pleats and a crappy drainback valve and design. Things may have changed
Threads Similar to: engine oil
havnt seen anything about engine oil? slater 2005 - 2010 21 July 23rd, 2010 09:51 AM
engine oil dgt_mustang V6 Mustangs 8 February 10th, 2009 10:38 PM
Engine Oil alabamastanger 99-04 20 January 25th, 2008 12:01 PM
engine oil? vacapro31 96-98 7 February 17th, 2007 06:34 AM
Engine Oil Question 4point6GT 96-98 5 October 8th, 2006 09:45 PM
