1989 GT 'vert
Mild build plan. Suggestions/advice?
This is the plan I've started with, I'd really appreciate inputs and advice! Thanks!
'89 GT Vert with Cobra intake, Accufab 65mm TB, Trickflow Twisted wedge heads, and probably a mild cam (suggestions?). I already have the intake and TB, planning on 70mm MAF programmed with 24# injectors, and the heads/cam are coming after the holidays. Not necessarily set on the trickflow heads, but I know a guy who's selling them for what seems like a pretty good deal. (~$900 new). After all this stuff is bolted on, also planned for a tune. Does this sound like a decent first time upgrade? I'm trying to have a plan first! Any thoughts/suggestions would be greatly appreciated. Also, is there anything extraneous I would need since these are basically bolt on parts? Thanks again for your time. |
1992 Lx
11.39@119.24
900 new is good, and the cobra intake doesnt line up very well to the tf heads, if I was in your shoes Id sell it and buy a used tfs-r and slap a tfs 2 cam in it
1991 Mustang LX 5.0
And if you did that, then you might as well pitch the 65mm tb for a 75 or 90mm depending on which TFS-R upper you would get, and then the Abaco 85 or 97mm depending on the above TB size and then you'd be getting somewhere. LOL the shit never ends.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1989 GT 'vert
If the cobra intake doesn't line up very well, does it need any modification?
1991 Mustang LX 5.0
Find the closest fel-pro intake gasket to the head that you use, and portmatch the intake and head to that.
#6 | |
'89 LX 'Vert
10's or bust... Literally.
same set up as me, but different intake manifold, and I made 321rwhp, with a hurt bottom end. but you are going to need a bigger throttle body, and good supporting mods, such as exhaust, maf, injectors, fuel pump, etc.
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
#7 | |
1992 Lx
11.39@119.24
1989 GT 'vert
It already has exhaust, but will be getting headers later, otherwise bone stock....for now ;-)
MAF and injectors will probably be next realistic purchase. |
Porting the Cobra lower for the TW heads makes a nice street/strip combination. Not hard to do if you have the tools and time. Here is a guide I did for a stock lower - the same techniques are used for the Cobra lower.
EECTuning.org • View topic - Intake Porting Guide
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
1991 Ford Mustang GT
go with a bigger mass air
1989 Black LX---Turbo
Direct qoute from Fox Lake Power Products frequently asked questions section.
![]() What are the major differences between the Trick Flow Street Heat, Track Heat, and "R" intake manifolds? While the Street Heat and Track Heat intake manifolds use the same exact lower, the upper on the Track Heat has runners that are 3" shorter inside the manifold. While they look identical from the outside, the Track Heat is more suited for forced induction or higher RPM applications and the Street Heat is more suited for idle-5500 RPM applications. The "R" intake is definately more of an intake for high RPM or large cubic inch motors. The "R" intake is not designed for a 302 cubic inch motor unless it is used with 15+psi boost.
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 Last edited by horsepowerjunkie; November 30th, 2010 at 05:45 PM. |
hmm, I had SH length at 15" and TH length at 13" - who's right, or what changed? I know they changed the TH length once before by an inch.
I would stick with the gasket matched Cobra intake, and go with a Trick Flow Stage 1 cam. That will make a nice mild street combo!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
95 Mustang GT
Dont put the MAF and injectors on next, buy them if you want, but dont install them now, until you have all the other mods, you dont need them and it will run rich
![]() People should think about boarding up their glass house before starting a rock fight! |
Threads Similar to: Mild build plan. Suggestions/advice?
| 2.3 t build plan question | Spike Digidy! | 2.3 Mustangs | 0 | July 19th, 2010 07:49 AM |
| well... what to plan for??? termi swap or build? | norcalam2 | 99-04 | 14 | November 9th, 2009 12:48 PM |
| My build plan! | 4.10GT | 99-04 | 19 | September 25th, 2009 03:09 PM |
| GT Build Plan | MikeJones | 99-04 | 78 | September 6th, 2009 11:19 PM |
| my build plan (in the making) | Danderson | 99-04 | 6 | February 12th, 2009 10:51 PM |
