Need help on mass air meters....
Old November 27th, 2010, 12:38 PM   #1
1989 Mustang Lx 5.0
roperracing is on a distinguished road
Send a message via Yahoo to roperracing
Okay so my ? is..... I have a 89 mustang..mass air.. has a A9L computer.. It has a trick flow stage 1 cam..and head work...stock uper n lower intake..with newer model 19#injectors under drive pulleys... .. has a msd box and blaster 2 coil..reason im telling u all of this is b/c i want to upgrade the mass air meter and go biger and i have a hypart chip taht came out of a 95 must gt..i wanted to see if i could use the chip in my computer? And i wanted to see if i could use a 96-04 mass air meter on it and i was going to upgrade the tb also.. i have a 98 model tb but i dont think i could use it...,But wasnt sure about the mass air and the chip? Any help would b nice......thanx...
Old November 27th, 2010, 12:51 PM   #2
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
you cannot use the chip, or that mass air. The TB will not work either.
If you are looking for a checp way to convert to a larger MAF, you want a 94-95 maf. Doesnt matter if its from a 3.8l, GT or Cobra. The just get the filter adapter ring that goes on it and drop it in place of your stock maf.... BAM.. 70mm maf upgrade!!
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old November 27th, 2010, 02:53 PM   #3
1989 Mustang Lx 5.0
the chip was in my 95 gt? so i cant use it? what if i got a 95 model computer? ...
And i wanted to just c if i could use the mass air body cuz its biger and change over my sensor in to it?.....
And i got a tb from a 95 i can use it on my 89..wats the benifits of using it over my 89 stock? tnx..
Old November 27th, 2010, 03:05 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
why dont you just do what Addermk2 said it sounds like his way will save you a shit load of time, money, and parts needing to be installed. what ever extra parts you already have from your old 95 stang just sell them on ebay, just because you have these parts doesnt mean you have to use them. some time when your set on using a specific part that wasnt ment for your vehical or set up can some time cost you alot more then its worth
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 27th, 2010, 04:30 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
So you know for sure the meter will put out the same voltage per mass as the stocker? If so how? THis has been a topic of debate between me and a friend, and neither of us can solve it.
Old November 27th, 2010, 11:05 PM   #6
the chip for the 95 uses a different computer program that is called a "strategy" It uses the CBAZA strat, where your fox ECM uses the GUFb strategy. So no, you cant use it... That would be like trying to stick a CD-rom into a 3.5" floppy drive.
As for converting to the 95 ECM. You COULD do it, but you would have to rewire a bunch of shit. And honestly, the fact that you need to ask about it, shows that you probably dont have the skills necessary to get the job done. No offence.
As for using the 95 throttle body, the TPS will not bolt down to it, the throttle cable connection is incorrect, AND the bolt pattern is wrong.
so again, NO... you cannot use it
I have compared many maf's to see which ones would come close to the stock flow values (electronically) of the stock fox maf. The results I cam up with is that the 94-95 SN-95 maf, while not being a perfect match, is the closest.
Here's the flow data.
If you take a look at this chart, you will see how close the actual flow values are to each other. Now compare this to the ever so popular (and completely stupid) upgrade to the 93 cobra maf.
this is the 93 cobra maf vs the stock fox piece. see how much further the flow curves vary?
[SIGPIC][/SIGPIC]
Threads Similar to: Need help on mass air meters....
Anderson fordmotorsports Mass Air Meters? 5.0 street stanger 5.0 Mustangs 5 May 27th, 2009 09:38 PM
do mass airflow meters go bad?? Mlx50man 5.0 Mustangs 5 April 1st, 2009 12:12 PM
