Mounting of Ignition Box??
Old April 29th, 2006, 09:40 AM   #1
Mustang8719 is on a distinguished road
Does anyone have Pics of where their ignition box is mounted.
I am going to mount the system in my Car today and wanted to see where everyone else mounted theirs.
Thanks for any pics or Ideas.
Eibach lowering springs,Intake ported to Max,Electric cooling fan,120Amp Alt.,FlowMasters,Jacobs FC1000 Ignition system with coil,King Cobra Clutch,APC Racing Seats
Old April 29th, 2006, 02:10 PM   #2
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
If you look on the other side of the upper radiator hose you will see mine. Make sure you use the rubber mounting blocks that come with it.
Old April 29th, 2006, 03:57 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Keep them away from engine heat. The number one cause of failure for MSD ignitions is improper installation, the next biggest cause of failure is heat.
Old April 29th, 2006, 05:15 PM   #4
GTXRacing is on a distinguished road
Mount yours in the glove box where it's away from that hot engine. MSD's are "known to break" only because of heat from the engine.
I am about to mount mine inside of my glovebox or on the dash wall.
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old April 29th, 2006, 05:40 PM   #5
Thanks mine is not actually a MSD but it is this one.
http://www.jcwhitney.com/autoparts/P...+10209/c-10109
I got a deal I couldn't refuse.
For now I have it mounted and hidden behind the Battery.
This is only for right now.
I will be moving some things around later and remounting.
Also it didn't come with rubber for the mountings. I will either add rubber mounts to it or mount with rubber between the box and the car.
Thanks everyone.
Old April 29th, 2006, 05:43 PM   #6
Not bad not bad
Yeah get it out of that engine and put it inside the car somewhere Like where I am going to put mine. Run to your hardware store and find some rubber fitting that will fit through the screws so you can mount. Or if you are going to mount inside the car. Don't worry about them.
Also, you might want to get a Blaster 2 Coil from MSD so you don't overload your stock one because it will happen.
GTX Racing
Tony P.
214-257-3635
Old April 29th, 2006, 05:51 PM   #7
Sorry I should have said earlier I have a new coil as well. This one
http://www.jcwhitney.com/autoparts/I...15000002005126
I will look monday at work I think I have small rubber mounts that will fit.
The are like a really small engine mount with studs on each side.
They almost look like the rubber mounts that are holding the Air box in on the cars. But they are smaller.
Old April 29th, 2006, 05:58 PM   #8
Those are exactly what you need. Just putting rubber hose over a screw will do nothing b/c the screw is still in contact with the mounting surface and the box at the same time and will still transfer shock and vibration.
Old April 30th, 2006, 12:02 AM   #9
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
mine is where bossmans is because my car was a four banger there is a hole behind it so it keeps it cool from the cool air rushing in the fender
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
Old October 22nd, 2006, 02:25 AM   #10
tag team's Avatar
tag team is on a distinguished road
i have mine behind my drivers seat mounted an my role cage.
Threads Similar to: Mounting of Ignition Box??
Need help with my NEX kit (mounting) steph V6 Mustangs 3 September 15th, 2007 09:14 PM
Amp mounting Bies08 V6 Mustangs 24 August 23rd, 2007 10:45 PM
C&L CAI - Mounting Bracket ? black07cs 2005 - 2010 3 February 10th, 2007 06:07 PM
shock mounting questions jagstang96 96-98 0 December 25th, 2006 07:48 PM
Reinforcement / mounting plate WAR-PARTY 99-04 1 October 15th, 2006 07:22 PM
