4500rpm cutout?
Old November 28th, 2010, 10:30 PM   #1
Tyfro!'s Avatar
1991 Mustang GT
Tyfro! is on a distinguished road
Question
4500rpm cutout?
i'm a new member. i got a 91 5.0 with a aod. Its just got a cheap intake and b&m shifter and full mac exhaust for now, but, when it his about 4000-4500 rpms it starts cutting out really bad and falls flat on its face. if i ease into it real real easy itll be fine. but if it gets stomped its goin nowhere, any help would be appreciated!
Old November 28th, 2010, 10:40 PM   #2
centipede3001 is on a distinguished road
fuel filter maybe ?
Old November 28th, 2010, 10:59 PM   #3
Tyfro!'s Avatar
1991 Mustang GT
has a brand new filter & pump,
Old November 28th, 2010, 11:02 PM   #4
2006 GT
11.99@114
1LOUDGT is on a distinguished road
Idk why the hell anyone suggest that.... My car just did this. It wasn't the ignition module (tfi) it was pick up sensor in the distributor.
2006 GT (Fastest)
2004 COBRA (Faster)
1990 LX 5.0 (Fast)
Old November 28th, 2010, 11:17 PM   #5
ryanw's Avatar
1991 Ford Mustang GT
check your fuel pressure that will give you an idea if its your fuel pump. an as for your fuel filter its only 8 bucks so thats a cheap thing to try
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 28th, 2010, 11:27 PM   #6
Tyfro!'s Avatar
1991 Mustang GT
those were the first things i did at the beginning of last month, the car was sittin for almost three years before the owner before me. he just got it running. not good. but running. i thought it might be injector related?
Old November 28th, 2010, 11:41 PM   #7
ryanw's Avatar
did you do a tune up ? plugs, wiers, cap and rotor, check your timing. what was your fuel pressure ?
255 fuel pump,
3:27 gears
Old November 29th, 2010, 12:19 AM   #8
Tyfro!'s Avatar
1991 Mustang GT
did that. didnt check timing. dont remember the pressure honestly, i can check it again tomorrow, what should it be at abouts?
Old November 29th, 2010, 12:42 AM   #9
ryanw's Avatar
35-40 i think
255 fuel pump,
3:27 gears
Old November 29th, 2010, 12:53 AM   #10
MacGuyver2978's Avatar
1989 Foxbody LX Notchback
11.67 @121.4
MacGuyver2978 is on a distinguished road
The first thing I would do is a base idle setting. Doing this will get you throttle body, throttle position sensor, and timing where it wants to be. I had a 95 gt that did the same thing. I bought it running but with a spun rod bearing. After the crank and new bearings install, it ran like shit after 3800 rpm. I finally did a base idle and it now pulls hard all the way through the tach.
Old November 29th, 2010, 01:09 AM   #11
Tyfro!'s Avatar
1991 Mustang GT
and how do you do that?
Old November 29th, 2010, 10:10 AM   #12
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Theres a sticky. Does the car ever shut off when driving for pro-longed periods of time?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old November 29th, 2010, 10:15 AM   #13
smott's Avatar
1994 GT
11.75@120
smott is on a distinguished road
Sounds like a timing issue. My car did the same thing when the timing was super retarded, id set base timing and give it a shot. The computer adjusts the timing depending with the vacumm so maybe thats why it does it, unless your really easy on it and the computer see's alot of vacumm????
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers...
E/T: 11.75 @ 120mph 2.0 60foot
Threads Similar to: 4500rpm cutout?
Bumper Cutout 6DXR 2005 - 2010 6 March 10th, 2009 07:46 PM
Grille w/cutout 94grreenmachine 94-95 4 February 26th, 2009 06:50 PM
Mustang cutout Archy88 Visual 13 May 10th, 2008 07:16 PM
Cutout question? mustangmanic 99-04 31 March 3rd, 2008 11:32 PM
V6 Bumper Cutout chromestang01 V6 Mustangs 20 February 1st, 2008 10:56 PM
