Need help on diagnoses
Old November 29th, 2010, 08:19 PM   #1
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
b-on-b 5.0 is on a distinguished road
So my car was running great 347 stroker fully built blah blah blah..just reached about 800 miles on the motor
so i am driving through a neighborhood stop at a stop sign and just gradually take off from the stop sign..(car was warmed up and was just cruising it prior to this everything was completely fine) the second i started to accelerate( not romping on it) the car seem to start hesitating and like cutting out seeming as it was running on 7 cylinders.. so pulled over shut the car off checked all wires, vacum lines, computer chip, and ignition wiring everything checks out and is fine no holes rips or leaks....so i am trying to figure out wtf happened...check iac, maf, distributor, the spout for the distributor, and tps all are still hooked up..no check engine light came on or anything but it seems like the car stopped firing on all cylinders and has a weird pitch in the exhaust now..oil pressure is still great and is not smoking one bit and has no crank case pressure...so any ideas wtf it is? no loud nosie or anything bad coming from the motor motor idles fine but when it trys to rev up..in gear or not it seems like it is running on 7 cylinders or something and hesitating...so idk what the deal is..guna pull plugs next..figured if a rr came loose it would be making a hell of a racket so idk..
Old setup
93 cobra motor, supporting mods, 11.5psi out of
V3 S-Trim made 422.5rwhp and 450 rwtq
ran 12's at 5800 ft above sealevel
new setup 347 on 11psi made 616.9rwhp and
576.0rwtq
Old November 29th, 2010, 09:00 PM   #2
MacGuyver2978's Avatar
1989 Foxbody LX Notchback
11.67 @121.4
MacGuyver2978 is on a distinguished road
I'm not sure what the proper name of it is but change the castle top looking thing in the distributor that's just under the rotor. I had a 94 gt that came real close to me pulling my hair out doing the exact same thing you are talking about. I was just about ready to change the whole distributor even after I had already changed everything inside it except for the castle. I decided to change it before a distributor was bought and the fixed the problem.
Old November 29th, 2010, 09:05 PM   #3
ryanw's Avatar
1991 Ford Mustang GT
i think they call it a "dizzy"
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 29th, 2010, 09:50 PM   #4
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
nope distributor and all ignition is brand new and distributor cap and rotor are brand new and perfectly fine
Old setup
576.0rwtq
Old November 29th, 2010, 09:51 PM   #5
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
fuel pump relay went out though so idk if thats the problem or not will change it tomorrow and see
Old setup
576.0rwtq
Old November 29th, 2010, 09:54 PM   #6
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
keep us updated
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old November 30th, 2010, 12:14 AM   #7
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
for sure
Old setup
576.0rwtq
Old November 30th, 2010, 12:20 AM   #8
moneymo's Avatar
1991 Mustang Gt 5.0
moneymo is on a distinguished road
Keep us posted bro
91 Mustang Gt
306/Under Drive Pulleys/gt40 heads/ so many more goodies
Threads Similar to: Need help on diagnoses
got the diagnoses today bobnasty 99-04 7 May 3rd, 2008 02:57 PM
