rear control arm bushings?
Old November 30th, 2010, 03:08 AM   #1
93HatchsBFF's Avatar
1989 LX
12.60 at 109mph
93HatchsBFF will become famous soon enough93HatchsBFF will become famous soon enough
So i swapped out rear ends for a set of 373s and the bushings are all cracked and dry rotted wheres the best place to find a set? and should i go poly?
1989 LX mustang, 5speed, 108,xxx miles, Mac Longtubes, BBK midpipe, Paxton Novi 1000 6psi, Crappy FMU with 19lb injectors, 373 gears
soon to come
30lb injectors, Blow through MAF, intercooler and tune
Old November 30th, 2010, 04:07 AM   #2
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
you could find a set on ebay or summit
Old November 30th, 2010, 06:21 AM   #3
1989 LX coupe 5.0L
89lx is on a distinguished road
i bought a set of edelbrock adjustable uppers and they came with new bushings
Old November 30th, 2010, 07:45 AM   #4
lcorriveau3's Avatar
1999
YAWN!!! what??
lcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura about
The poly bushings will help tighten/firm up the suspension but you will get more NVH.
I swapped to poly bushings in the rear arms this summer and the noise level was a noticable increase.
Old November 30th, 2010, 07:52 AM   #5
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
what are you doing with your last rear?
what gears are in it?
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old November 30th, 2010, 07:55 AM   #6
The Big Spoon
never fast enough
i am rocking lowers from maximum motorsports with aluminum spherical bushings. there is a little bit more noise but definately not anything to complain about. I definately wouldnt worry about urathane. I typically hear the most of it when accelerating through third gear.
the noise goes away then i turn the stereo up or when my wife is yelling at me to slow down
Black Stang Crew
Old November 30th, 2010, 11:44 AM   #7
1989 LX
12.60 at 109mph
thanks guys for the info. ive just been having a clunking issue ever sense i traded my buddy rear ends and his bushing were a little cracked so im thinkin thats what it is.
soon to come
Old November 30th, 2010, 11:54 AM   #8
Most suggest against using poly on uppers because they cause more binding issues... it'll cause more binding. Just do rubber or if you don't mind allot of noise the spherical bushings.
Old November 30th, 2010, 12:07 PM   #9
1989 LX
12.60 at 109mph
why do the polys make noise?
soon to come
Old November 30th, 2010, 12:12 PM   #10
The Big Spoon
never fast enough
more dense than rubba
show some sack and do aluminum spherical!
Black Stang Crew
Old November 30th, 2010, 12:19 PM   #11
1989 LX
12.60 at 109mph
where can i get the spherical ones?
soon to come
Old November 30th, 2010, 12:23 PM   #12
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
They don't make noise, they just transmit it better.
Unless you don't lube them, then they squeak, but that's not the noise most are referring to.
If you've got the budget, I wouldn't waste my time replacing rubber bushings. Just get a set of decent LCAs. If you're straight-line only, poly/poly is cheap and should be good enough. If you can afford it, sphericals are better than poly (more freedom of articulation AND stiffer), but again transmit more noise. For the uppers, skip straight to sphericals.
O o
/¯/______________________
\_\
Old November 30th, 2010, 12:24 PM   #13
Any of the good, know, name-brand suspension companies sell them. Maximum, Griggs, Steeda, Team Z, BMR, etc, etc, etc.
O o
\_\
Old November 30th, 2010, 12:29 PM   #14
1989 LX
12.60 at 109mph
thanks man i was thinking about doing uppers and lowers from american muscle but i was also thinking just buy some bushings to get my by for now i got other things to do first before upgrading the suspension
soon to come
Old November 30th, 2010, 12:37 PM   #15
What would come before suspension?
O o
\_\
Old November 30th, 2010, 12:45 PM   #16
The Big Spoon
never fast enough
sfc's
adding power first would just be plain silly
Black Stang Crew
Old November 30th, 2010, 01:17 PM   #17
1992 Lx
11.39@119.24
slicks so he can pull 1.6s on bone stock suspension
Old November 30th, 2010, 01:30 PM   #18
^^ he better let you drive then
Old November 30th, 2010, 01:35 PM   #19
1992 Lx
11.39@119.24
sucks his cars 4 lug and my shits 5 or we could each buy 1 new slick LOLZ
Old November 30th, 2010, 01:46 PM   #20
Psh, 4-lug is for sissies
O o
\_\
Threads Similar to: rear control arm bushings?
Rear Control Arm Help - Finding new Bushings The Novice 5.0 Mustangs 4 July 26th, 2008 09:35 PM
rear control arm bushings rakkassan34 2005 - 2010 1 July 15th, 2008 07:16 AM
Rear control arm bushings Stangzilla 5.0 Mustangs 7 June 2nd, 2007 12:50 AM
control arm bushings angermgt 5.0 Mustangs 5 May 15th, 2007 07:30 PM
