2001 Mustang GT
13.8@101.58mph!
Weird noise coming from rear
So last night i take off from a light and hear this kinda loud spinning noise coming from the under the reaer of the car.It started doing it when i got on the gas at about 25-30mph.It only does it if im moving.Sound like u-joints?How do i to tell if there bad?
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
1992 Lx
11.39@119.24
theyll have play in them
2001 Mustang GT
13.8@101.58mph!
I just went around the block a few times,to try and replicate the noise.Now i can barely hear it.I tried listening for clicking but i coldnt.How much do shops carge to put new ones in?
1992 Lx
11.39@119.24
theyre not hard at all to put in dude, just need a hammer
2001 Mustang GT
13.8@101.58mph!
How can i tell its
definately them
1990 mustang gt
Wouldn't it make a noise at all speeds if it is the u joint?
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
2001 Mustang GT
13.8@101.58mph!
Thats what i thought.I was looking on the interwebs,and found some things about a "center support bearing" making a whirring,spinning noise.Now what the hell is a center support bearing,and where does it go?
95 Mustang GT
center support bearing could be your problem if you say its a spinning noise, a u joint would be more of a clunking sound when you take off or switch gears, the center support bearing is on the drive shaft it drops down from the floor of the car and holds the drive shaft in place (supports it)
![]() People should think about boarding up their glass house before starting a rock fight! |
2001 Mustang GT
13.8@101.58mph!
Its not clicking or clunking at all.Whats something like that cost??
95 Mustang GT
about 15-20 bucks at autozone, and do it yourself, its super easy.
1989 GT
Sounds like either u-joints or pinion bearing..
Get under car and see if there is oil leaking at pinion seal, that's first sign of it going out....if not, twist driveline back and forth to see if there is slop in u-joints. You may have a dry joint.
'89 Mustang GT, 5 speed '87 Chevy 3+3 Dually,454, lowered '78 Chevy SWB, 454, slammed '68 Dodge Charger R/T, 440 4 speed '66 Impala mild custom '27 Ford Model T coupe '60's style. |
2001 Mustang GT
13.8@101.58mph!
i know im a noob,but is there a how-to online?Also how can i tell thats reall the problem??
#13 | |
1990 mustang gt
#14 | |
1989 GT
And no...1 piece drivelines do not have carrier bearings...mostly used on longer wheelbase cars/trucks...like older station wagons and long bed pickups.
#15 | |
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
if you have a high frequency viberation, I'd say it is the u joint. If you don't have a vibe, I'd say that a bearing in your rear (most likely pinion bearing) is spanked. |
2001 Mustang GT
13.8@101.58mph!
I was at a red light and i thought it was running shitty,then i punched it and heard that whirring spinning noise.After about 25mph i heard it going with the rpm's.
1989 GT
Check the rearend.....sure sounds like pinion seal or rear cover leaked and now yer outta oil....and the sound would be the ring and pinion mesh without oil.....the pitch of the sound will change with rpm...
2001 Mustang GT
13.8@101.58mph!
Sounds logical.Shes going in zee shop monday,so i can it taken care of.I checked the cover and it does look like it leaked.It looks kinda old though.
95 Mustang GT
Didn't think a fox had them, but he said someone said carrier bearing. I simply explained what and where
2001 Mustang GT
13.8@101.58mph!
Its all good
Threads Similar to: Weird noise coming from rear
| squeaky noise coming from passenger rear | mystk96 | 99-04 | 28 | May 15th, 2012 11:06 AM |
| rubbing/grinding noise coming from rear? | Ruffellbaker | General Tech | 1 | July 21st, 2010 08:23 PM |
| Weird noise from passenger rear tire!!! | huggy bear | 99-04 | 2 | June 6th, 2010 01:56 AM |
| weird noise coming from my motor during initial warm up | G.T. Rags | 96-98 | 21 | April 22nd, 2007 02:42 PM |
| Strange Noise Coming From My Rear | 92_fox | 5.0 Mustangs | 12 | November 14th, 2006 09:58 AM |
