Need quick help car wont start...
hey whats up guys im new to this site.... got a lil prob just finished my build in my fox body had the car running for about and hr... on and off several times. had the car running then she just quit like it ran out of fuel..threw more fuel in her and still wont fire... things ive checked...
fuel pump is working correctly- i have pressure at the rails checked the relay under the seat ..looks clean checked for spark i have a spark but nothing crazy...like orange i have yet to change the coil its the oem one from 88 still im left to believe this is my problem...not enough spark need a new coil ? what do u guys think thanks for the help. |
helppppppp
1991 Mustang LX 5.0
Fuel/spark/air/timing... That's what makes 'em run. What was your pressure at the rails? Did you use a gauge? Did you set your initial timing anywhere from 10-14 btdc?
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
all is good like i seaid car was running prior to this for and hr or so
i have fuel spark air timing is good... i have weak spark possible the spark is too weak like the coil craped out on me?
hmmmmmmmmmmmm
1991 Mustang LX 5.0
So... I'm guessing you're really saying that you don't really have the spark then, huh?
You should get several blue sparks, if you don't then its your Ignition Coil.
Take your ignition wire off the distributor and lay it on the intake, try and start it. You should see several blue sparks come out repeatedly, if they are not blue or you only get 1 or 2 then the problem lies in the ignition coil.
1991 Mustang Gt 5.0
1+
91 Mustang Gt306/Under Drive Pulleys/gt40 heads/ so many more goodies |
just threw a msd coil and still no gooddd......................
plugs are wet from getting fuel...not fouled out..........
1991 Mustang LX 5.0
check your voltage to the coil.
Sounds like TFI then.
ok ill keep it posted
89 GT
Check your block and battery grounds.
1991 Mustang Gt 5.0
TFI i believe. Mine just went out as we speak so im waiting till tomorrow to get a new one.
problem was fuel pump....i was getting pressure 47lbs i belive it was and when the key was turrned i lost ALL FUEL pressure...i upgraded to a walbro 255 and that was the problem strange tho because it was working but apparently just not correctly thanks for the help guys!
89 GT
When you turn the key off you will lose all fuel pressure. How quickly it drops is how you tell if you have a leak/bad pump. If it drops almost instantly when you shut the key off then that pump was your issue. If it took like 15 mins to bleed off, then changing that pump and the car starting may have been coincidence and there still might be an issue that might pop back up again.
1987 347 vortech V-2
how old is the dizzy? check ignition module
And when you lose control you reap the harvest you have sown! |
Threads Similar to: Need quick help car wont start...
| Car wont start | ballajb | 5.0 Mustangs | 1 | November 18th, 2009 01:30 PM |
| Help Please Car wont start | TwitcH_SN95 | 94-95 | 10 | November 8th, 2009 09:27 PM |
| Need Help - Car wont start | The Novice | 5.0 Mustangs | 10 | August 7th, 2009 03:38 PM |
| car wont start, not sure why... help please | mustangracer2g | 96-98 | 13 | February 7th, 2009 09:34 AM |
