1990 Mustang GT
IAC help / idle help please
My '90 GT surges at idle going from 400 to about 1200 rpm, sometimes even dying. I replaced the IAC but it wasnt any better, maybe alil worse. When I unplug the IAC it seems to idle fine, no surging. Then when I plug it back in it idles like crap.
Any ideas or hints to try? I unplugged the IAC and shut the car off, now have battery unplugged. Will try plugging it all back in to see if it resets itself, but other than that im kinda at a loss.
'90 GT Vortec SI with pro-pipe Eibach pro kit KYB adjustable shocks/struts BBK headers/x-pipe/american thunders |
clean your maf, check and replace your O2 sensors, look for vac leaks...
all the normal jazz. However, this seems to be pretty normal when people add mods to their car but dont get it tuned, or tuned properly. you are probably running too rich at idle
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
did you set the idle properly ?
Mine was doing the same thing and i looked up the sticky on how to properly set the idle and now my cars idles a lot better but if you have a cam it might always move a little but it should jump from 400-1200 |
Threads Similar to: IAC help / idle help please
| Help with setting Idle and IAC restrictor plate | Timm10221 | 5.0 Mustangs | 3 | May 7th, 2010 11:38 AM |
| IAC Mod- Writeup for those of us with slow returns to idle. | 97GT4.6 | 96-98 | 8 | March 29th, 2009 05:24 PM |
| changed IAC, still have CEL and high idle | 97GT4.6 | 96-98 | 18 | March 27th, 2009 05:59 PM |
| Aftermarket TB/Plenum hanging idle/low idle issues! | Novanutcase | 99-04 | 12 | August 13th, 2008 11:24 AM |
| Idle Problems Code 1506, Idle Overspeed Error | jagstang96 | 96-98 | 3 | August 29th, 2006 04:11 AM |
