Clutch help.
LinkBack (1) Thread Tools
Old November 30th, 2010, 10:09 PM   1 links from elsewhere to this Post. Click to view. #1
1985 Mustang GT
12.89@107.72
xxvicarious is on a distinguished road
Send a message via AIM to xxvicarious Send a message via Skype™ to xxvicarious
Clutch help.
1985 5.0 5 speed. Ill start the car, let out the clutch, and I hear a light ticking sound when the clutch is all the way out. Push it back in, it immediately goes away... The car gets hard to put into gear. 1st, 2nd, doesnt
matter. Takes a lot of pressure to throw it in gear.
Sorry, I know this is an easy answer, this is the first manual transmission car
Ive owned in about 4 years. Im guessing its the throw out bearing? Any direct answer would be great. Thanks.
Old November 30th, 2010, 10:24 PM   #2
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
It could be that or the clutch disc or pressure plate
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old November 30th, 2010, 11:56 PM   #3
1985 Mustang GT
12.89@107.72
So, looks like Im getting a whole new clutch assembly huh? If I drive it for a few more weeks (babying it), think itll mess anything up?
Old December 1st, 2010, 12:22 AM   #4
1985 Mustang GT
12.89@107.72
What would be a good clutch to put in the 'stang, without having to replace the flywheel? I want something stage 1, but I really dont want to replace my flywheel.
Old December 1st, 2010, 12:55 AM   #5
1992 Lx
11.39@119.24
throw out bearing
Old December 1st, 2010, 08:01 AM   #6
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
If you put a clutch in it, you need to take the flywheel off and resurface it, unless you want your clutch to not last long.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old December 1st, 2010, 10:57 PM   #7
1985 Mustang GT
12.89@107.72
Ill do so, I just dont wana fork out the $ for a new flywheel.
Old December 2nd, 2010, 09:10 AM   #8
before you go spending money why not make sure the clutch is actually adjusted properly or not stretched? if it's not and it's too tight like it sounds it'll ride the throw out bearing and cause premature failure of the throw out bearing, synchros etc
Where does the clutch grab at? high on the pedel or right off the floor?
Old December 2nd, 2010, 12:06 PM   #9
1985 Mustang GT
12.89@107.72
Right off the floor. I can let off the clutch about 1/4 inch before the clutch
starts grabbing. Ide say the last inch before my foot comes completely off
the pedal is useless, doesnt go anything.
Ill be honest, this is my first manual transmission car in yeeeeeears, I know
nothing about them. Ive rebuilt many nice motors, dropped plenty of em in
cars, done a lot of fabrication work... But Im lost when it comes to even
adjusting a clutch Its sad, I know. But Im just bein' honest hahaha.
Old December 2nd, 2010, 03:00 PM   #10
Ideally you don't want the clutch to grab right off the floor because when your racing you'll have to pound down to the floor in order to engage the next shift when if adjusted properly you should have to only go about half way down to to engage the clutch. Also means the clutch is either not fully engaging or not fully releasing which damages parts prematurely.
Your clutch engaging an inch off the floor means either your cable has stretched to shit(common) and needs to be replaced or if you have a firewall adjuster it's adjusted too tight. Either one will cause premature damage so take it easy on the car until you sort this out.
So to me it sounds like a for sure purchase here is a new cable... throw out bearing reminds to be seen since the cable is so bad. So what I would do is purchase a cable/adjust/quadrant kit from maximum motorsports (best setup out there) and swap those in. Jerk around with the adjustment on the firewall adjuster until you get it to where you want it which should be mid way on the clutch pedel. Clutch Cable, Quadrant, and Firewall Adjuster Package [MMCP-51] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
If the throw out bearing's still making the noise then you know it'll have to be replaced which involves yanking the trans and clutch setup.. I'd baby it until your ready to purchase a clutch kit then do both at the same time but like I said try the cable setup first because it's a sure thing where as if you cut right to the TOB replacement you may not even need it yet.
let me know if that doesn't make sense im typing it up as four people are talking to me (im at work)
Old December 2nd, 2010, 03:01 PM   #11
1992 Lx
11.39@119.24
you have to remove the clutch to put a new tob?
Old December 2nd, 2010, 03:05 PM   #12
LOL I know that sexy
Old December 2nd, 2010, 03:10 PM   #13
1992 Lx
11.39@119.24
I was being sarcastic daaawg. Unless Ive been doing it wrong lolz
Old December 2nd, 2010, 07:32 PM   #14
1985 Mustang GT
12.89@107.72
Ya, makes sense. Thanks for the help, much appreciated. Can I adjust the clutch from the firewall with the car running to see if that annoying clicking goes away? Or does the car have to be off to make adjustments?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/194178-clutch-help.html
CLUTCH ENGAGING FLOOR | BoardReader This thread Refback January 11th, 2011 05:26 PM
Threads Similar to: Clutch help.
clutch pedal vibration and excessive clutch chatter mscribellito 99-04 13 August 19th, 2010 04:59 PM
Clutch Or Clutch Cable OR Shifter??? 96GtGoodz 96-98 21 July 27th, 2009 02:59 AM
clutch replacement- replace whole clutch assembly or just clutch disc? WilltheThrill 4V / SVT 12 December 13th, 2008 12:18 AM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 10:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 02:33 PM
