cobra intake vs. stock - Page 2
Old December 1st, 2010, 10:19 PM   #21
1992 Lx
11.39@119.24
You don't need to disconnect the cable to pull your motor. Jack it up a lil and pull it while shaking it side to side. The input shaft is sticking in the pilot bearing
Old December 2nd, 2010, 02:11 AM   #22
92ponylx's Avatar
92 Lx
Slow
92ponylx is on a distinguished road
i have all the bolts out. i have the jack torwards the tailend of the trans and i was shakin the piss out of it while tryin to bring it back some and it wouldnt budge... should i try to remove the 4 bolts holdin the trans to the bell?
Old December 2nd, 2010, 02:28 AM   #23
91 mustang gt/90 7up vert
fordguy1280 is on a distinguished road
I
I would...
Originally Posted by 86er View Post
take the e cam, buy 3 more and make a table out of it
Old December 2nd, 2010, 09:58 AM   #24
1992 Lx
11.39@119.24
you pullin the motor or the tranny?
Old December 2nd, 2010, 10:25 AM   #25
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
I always pull the transmission first. Then remove the bolts for the bellhousing. Have you removed the starter?
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old December 2nd, 2010, 05:01 PM   #26
fogged306's Avatar
89 GT
The way I usually pull an engine is to pull the bellhousing with the engine. I unbolt the 4 bolts on the trans to bellhousing and shimmy clutch off the input shaft of the trans. Works well for me, plus you can do any clutch work you need to do sitting/standing as opposed to laying on your back.
Old December 3rd, 2010, 12:53 AM   #27
92ponylx's Avatar
92 Lx
Slow
I'm removing both engine and trans...also do i need to get a spacer with that intake. He has a 1/2inch and a 1 inch spacer
Threads Similar to: cobra intake vs. stock
Will stock 03/04 Cobra Springs fit a 99/01 Cobra and to what effect. pelicanruck 99-04 1 September 11th, 2010 01:16 PM
STOCK 00GT W/410'S VS 03 COBRA STOCK spero 99-04 35 March 22nd, 2009 07:00 AM
95' Mustang 5.0 HO intake swap for 93 cobra intake... stang9587 5.0 Mustangs 1 April 3rd, 2007 05:20 AM
