Engine problem?
Old April 12th, 2007, 07:09 PM   #1
gregkelley is on a distinguished road
Engine problem?
The car cuts off when I stop hard . The car has a holly 650 on it dont know if it has something to do with that. What could cause this?
Old April 12th, 2007, 07:16 PM   #2
Mine done that before for awhile. I think it was because the idle was set too low. I dont know why but when i would stop hard it would drop below 500 rpm sputter and come back up to idle or die....My suggestion is set the idle a bit higher, maybe to 750 or 800 and see what happens.
If that doesnt work or you already did do that, somebody else will chime in because my problem was fixed after that.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old April 12th, 2007, 08:40 PM   #3
ujslost's Avatar
is the timing to low?
Old April 14th, 2007, 12:45 PM   #4
The timing has been set I will try adjusting the idle.
Old April 14th, 2007, 05:09 PM   #5
angermgt's Avatar
angermgt is on a distinguished road
car could be runnin rich.
Old April 14th, 2007, 08:22 PM   #6
I tried increasing the idle it made it some better but it still stalls and cuts off on a hard stop? Would a weak fuel pump cause that? I think it is stock and mabey even a from a 4 cyl mustang. The glass in the fuel filter has a big air bubble in it and I have noticed a decrease in power.
Threads Similar to: Engine problem?
Engine flooding problem fastford3388 5.0 Mustangs 3 August 13th, 2007 10:33 AM
engine problem Pharoh V6 Mustangs 8 August 7th, 2007 07:32 PM
Problem with engine troy1000rr General Tech 6 June 6th, 2007 06:25 PM
ENGINE PROBLEM criptez V6 Mustangs 1 April 12th, 2007 11:12 PM
My Check Engine Problem OcOnnor220 99-04 9 February 8th, 2007 01:36 PM
