Battery relocation quiestion?
Old April 29th, 2006, 10:11 PM   #1
Mustang8719 is on a distinguished road
I was thinking about relocating my battery. I was thinking about doing it for 2 reasons.
1. Better weight distribution
2. to try to get rid of all the Noise through the Stereo system
The quiestion is will it get rid of the backround noise?
Instead of buying all the Expensive Filters to get rid of the noise if relocating the battey will also get rid of the noise I will try that first.
Thanks for any advise.
Eibach lowering springs,Intake ported to Max,Electric cooling fan,120Amp Alt.,FlowMasters,Jacobs FC1000 Ignition system with coil,King Cobra Clutch,APC Racing Seats
Old April 29th, 2006, 10:58 PM   #2
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
I noticed in your sig that youre running a 120 amp alternator. The extra noise youre getting may be coming from the axtra current comming out of youre alternator.
Old April 29th, 2006, 11:10 PM   #3
It was doing that before the Swap.
I kept burning up the stock Alternators. Almost lost the car 3 times to fire from it.
I have been through the wiring many times for the Stereo system and have Monster cables for the Rca's
Now that I installed the Ignition system I pick up noise from that as well.
Thats why I was wondering if moving the battery and eliminating the stereo wires from inside the car might fix it.
Old April 30th, 2006, 12:24 AM   #4
1gunner23 is on a distinguished road
are you useing a ferret cap? also is your ground bigger then your positive going to you amp?
Old April 30th, 2006, 12:31 AM   #5
No Cap Yet and the Ground cable is about the same size.
Old April 30th, 2006, 05:15 PM   #6
i have always heard that the ground should be twice the size of the hot wire, not sure if it is true? i think advance auto or some place like that sells filters fairly cheep also
Old April 30th, 2006, 07:59 PM   #7
I will try the ground wire thing. But if relocating will get rid of most of it the I won't need the Filters.
Old April 30th, 2006, 11:14 PM   #8
i just thought are you running a positive ground or a chassis ground?
Old May 1st, 2006, 07:02 PM   #9
173speed is on a distinguished road
didn't help my but i just get distortion when i play the radio
SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$%
Old May 1st, 2006, 07:18 PM   #10
My grounds are mounted to the Body in the trunk.
I have good Clean connections as well.
Old May 1st, 2006, 08:04 PM   #11
i built a ground kit from stuff that i got from radio shack and it help a little just rand different ground wires from the block to the frame and from the alternator to the frame and under the car from trany to the frame the ground that the fox come with are garbage ...
Old May 1st, 2006, 08:58 PM   #12
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
A chassis ground will be fine as long as it is a good one. As far as the size it really doesn't metter as most electrons travelling back to the battery are lost traveling through the frame back to the battery. A BAD GROUND IS THE #1 CULPRIT OF BACKGROUND NOISE IN YOUR CAR STEREO. That is all.
Old May 1st, 2006, 10:20 PM   #13
which is why i like to run a positive ground
Old May 2nd, 2006, 12:08 AM   #14
I will try playing with the wiring a little more to see if I can make it better or get rid of all of it.
The EQ is starting to Act up again. Time to take apart and check solder connections again.
Threads Similar to: Battery relocation quiestion?
Hatchback battery relocation pyrofenix 5.0 Mustangs 7 June 26th, 2007 03:40 AM
battery relocation with second battery onewinner 5.0 Mustangs 1 May 30th, 2007 12:30 PM
battery relocation onewinner 5.0 Mustangs 13 May 29th, 2007 04:17 AM
Battery Relocation 90Stang 5.0 Mustangs 11 April 16th, 2007 08:31 AM
Battery Relocation 98vortech Modular Mustangs 0 September 14th, 2006 07:23 PM
