fuel tank probs
Old December 1st, 2010, 11:00 PM   #1
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
fuel tank probs
the guy i got my stang from said he had just put a fuel pump in the car. the fuel guage does not work, and after seing the wires wire nutted with yellow house wire nuts (seen this while running my battery cable to the trunk)i can only imagine why i pretty much fill it up after every days trip. more than once when i havnt filled it up in a trip our two the car will cut out around a curve(very hilly and curvy around here) going strait to the gas station and filling up fixes the problem. the only weird thing about that is the car only will take about 9 gallons to fill up. that means its cutting out with like 6 gallons in the tank wtf! this happend a few times when i first got the car and hasnt happend in a while because i stay on top of keeping the tank full.any sugestions? i think i allready know i will probly have to drop the tank to investigate,but that sucks,no garage,start of winter,and if im going to drop this damn tank it's going to cost some coin i doint have right now for a high perf pump,sending unit ect.... has anybody else had this problem?
Old December 1st, 2010, 11:22 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
If I were to guess, I would say that he's got the fuel pump too high in the cage somehow As far as the sending unit, he may have forgot to plug that back in on the tank... Ask me how I know, lol
I do it nice, cuz I do it twice, hahahaha
Old December 2nd, 2010, 10:15 AM   #3
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
It's not hard to drop the tank to check it out
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old December 2nd, 2010, 10:23 AM   #4
1992 Lx
11.39@119.24
fucked up the float/sending unit somehow. Drop the tank its 2 bolts and some hoses
Old December 2nd, 2010, 07:13 PM   #5
1991 Mustang LX 5.0
Don't forge the three 10mm bolts at the filler neck. 8mm on the filler neck holding bracket under the car, and 14mm (I think) on the tank straps. Blow off or vacuum the area around the locking ring before and after you loosen it to avoid getting dirt in your tank. It's cake. You may or may not want to get a new filler neck grommet before you do this too, sometimes they tear during the process. They are 1/2 the price through Latemodel than at the dealer, but that's if you are ordering other crap too since there will be shipping charges.
Old December 3rd, 2010, 07:36 AM   #6
1991 gt vert
it's just weird that the car starts cutting out,and then only takes 9 gallons to fill it. that should leave 5-6 gall that was in the tank. it's hapend a few times and i'm shure that it's the fuel cutting out. cuts out only making a hard quick turn,or hitting a hair-pin curve(three of them between my house and the main rd),but drive straight its fine.
Old December 3rd, 2010, 03:45 PM   #7
1991 Mustang LX 5.0
DROP THE TANK. SOMETHING IS WRONG WITH THE PICK UP, OR YOU HAVE A HALLACIOUS DENT IN YOUR TANK. Clear enough?
Old December 3rd, 2010, 09:01 PM   #8
1991 gt vert
i know it just suCk to drop the tank and not have the coin to putt a better fuel pump in
Old December 3rd, 2010, 09:07 PM   #9
1991 Mustang LX 5.0
It's easy to do and doesn't take much time at all. You can always drop it again at a different time to change the pump. I bet you can have that tank sitting on the ground in 20 minutes with hand tools and a floor jack
Old December 3rd, 2010, 09:47 PM   #10
bkatrenak84 is on a distinguished road
thats kinda weird actually my fuel gauge doesnt work right.. when my tank is full it reads empty however ONLY when its almost empty the gauge starts going up i can go about 180 miles before i see the needle move at all then another 30 before i get nervous about how much is left so i fill it....any suggestions on my end? or maybe same as this guys?
Old December 3rd, 2010, 10:17 PM   #11
1991 Mustang LX 5.0
Sending unit is prolly done. You can use an ohm meter on the sending unit and raise and lower it. You should see a smooth fluxuation in the ohm reading. I believe this will help Auto Meter
Old December 4th, 2010, 08:26 PM   #12
thats kind of funny you used autometer, because my car is technically an 81 but its got 88 everything minus interior on it, and the gauges are all autometer gauges
Old December 4th, 2010, 08:44 PM   #13
fogged306's Avatar
89 GT
Sounds like the baffles in the tank are broke. They form a wall around the pick-up for that exact reason, when you go around turns, fuel doesn't slosh away from the pick-up and cause the car to stall. I've had a tank do that once before and when I took it out and shook it, you could hear the baffle knocking around inside the tank.
Old December 4th, 2010, 09:31 PM   #14
1991 gt vert
thats more along the lines i was thinking also. like i said it starts doing this when there is (should be if its a 15 gallon) 6 gallons still in the tank! i might just wait on investigating this till i have the money to put a new high flow pump and new cage and sending unit (maybe a new tank) in the car. i'm a roofing sub-contractor and work is getting slim right now. as long as i keep the tank full it never happens
Old December 5th, 2010, 10:41 AM   #15
yeh just do it all one shot,tank pump unit everything in there replaced with good stuff and there ya go, it should last the life of your car unless you keep it until youre 90 lol
Old December 5th, 2010, 01:06 PM   #16
95tbirdv8's Avatar
1990 mustang gt
Maybe you'll find a bag of money in there. If you do I claim half lol
Threads Similar to: fuel tank probs
Gas Tank Leaking?? How to Drop your Fuel Tank / Replace the Filler Neck Gasket gills99stang 99-04 66 May 19th, 2012 02:49 AM
Fuel Tank aussy2121 V6 Mustangs 6 April 4th, 2009 11:28 AM
OEM located fuel cell / replacement fuel tank carloverx 5.0 Mustangs 10 June 20th, 2008 08:15 PM
Need Fuel Tank Help mikebert 5.0 Mustangs 2 December 10th, 2006 10:43 AM
