1989 2.3 notchback
Our car turns corners
sn95 a arm swap + mstr cyl?
Car is 89 lx 2.3 5spd. Going to 5 lug. Parts I have are: 2000 v6 a-arms, spindles, rotors, calipers. Rear is Aerostar 10" drums/axles.
My question is. How hard is it to change the inner tie rods on my 89 rack. I know I will need to do this to reach the longer a-arms. Can I just thread out old and thread in new? Do I have to take the rack completely apart? Can I swap on a 2000 rack to match? Also with the dual piston front calipers, will I need a new master cyl? If so, one with a larger bore or smaller bore? Are the rear wheel cylinders from the Aerostar larger, smaller, or same as my old stock 9" units? Also if it matters, this car will see 100% track time and NEVER see the street.
"nitrous is for guys who can't build motors" |
you dont need the v6 control arms, all you need is 94-95 balljoints.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
1991 Mustang LX 5.0
Unless you are going for a wider track width, which I'm guessing you are because of the purpose of the car.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
shouldn't need to upgrade the master cylinder unless you convert to discs in the rear as well.. then you'd have to mod/gut the prop valve as well
Threads Similar to: sn95 a arm swap + mstr cyl?
| Flat-tappet 302 Cyl head swap | Mustangfan99 | 5.0 Mustangs | 4 | April 18th, 2008 04:42 AM |
| 4 cyl swap...rear brake line | Way_Fast_Whitey | 5.0 Mustangs | 14 | September 6th, 2007 10:04 PM |
| motor swap 4 cyl to 8 ??? | sk8daily69 | 5.0 Mustangs | 3 | December 25th, 2006 02:22 PM |
| Looking for someone who has actually done a 4 cyl-8 cyl swap | OTreborO | 5.0 Mustangs | 0 | August 17th, 2006 11:16 AM |
| Things I noticed when doing the 5.0 swap into 4 cyl car | OTreborO | 5.0 Mustangs | 6 | July 26th, 2006 05:47 PM |
