header help needed
Old December 5th, 2010, 01:26 PM   #1
fox50's Avatar
91 gt
fox50 is on a distinguished road
Question
header help needed
i just installed bbk shorty equal length headers. steering rod is rubbing the header. what can i do to fix this problem?
Old December 5th, 2010, 01:34 PM   #2
fogged306's Avatar
89 GT
Check your motor mounts, they may be sagging or not lined up correctly.
Old December 5th, 2010, 01:47 PM   #3
fox50's Avatar
91 gt
if i jack up the motor with the mount loose it clears. can i tighten the mount with it raised and will it stay in place ?
Old December 5th, 2010, 02:01 PM   #4
FastStang91Lx's Avatar
1991 Mustang LX 5.0
You can tighten one side higher or lower than the other, if that's what you are asking.
Old December 5th, 2010, 02:28 PM   #5
fogged306's Avatar
89 GT
BBK usually doesn't have issues fitting so if they're not fitting, either the car's tweaked or the mounts are shot. There is a chance it's the headers but it's not likely. You can try to bolt the mounts down while it's jacked up and see what happens, but if it doesn't work it's probably your mounts.
Old December 6th, 2010, 10:58 AM   #6
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
my BBK equal shorties rub on the steering rod as well. they rubbed when i bought the car in march, and they still rub after i swapped on a set of solid mounts. i havent had any problems with it though.
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old December 6th, 2010, 11:08 AM   #7
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
replace your motor mounts... they have gone bad on you.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old December 6th, 2010, 07:46 PM   #8
1991 Mustang LX 5.0
But aren't solid mounts shorter...?
Old December 7th, 2010, 01:30 PM   #9
'88 Mustang GT
im sure the stock mounts were shot at the time, but the steering rod had a nice smooth groove from the headers worn into it, and contact is still made with the solid mounts. ill eventually be swapping a 351w into the car, with longtube headers and everything, so im not to concerned about it now.
Old December 7th, 2010, 07:00 PM   #10
1991 Mustang LX 5.0
What I meant was, that if the mounts are shorter, you would be closer to the rod, unless you knew what I meant. Then just disregard
Threads Similar to: header help needed
Anybody removed all header bolts with k member, motor, and header still in car?(lts) The Unknown 7 99-04 50 November 6th, 2010 07:10 PM
header ? for all 91sleeper 5.0 Mustangs 3 June 23rd, 2010 12:26 AM
header? quick96cobra 4V / SVT 6 March 8th, 2009 07:13 PM
Help with header bolts - Locking header Bolts? Rush 94-95 4 February 4th, 2009 04:37 PM
header mustangjl 99-04 0 December 26th, 2007 10:45 PM
