my windows dont roll downwhat up both my power windows on my 94 gt will not roll down there is nuthing happining checked fuse changed switch still nothing i want to convert to manual can anyone help me with this or help fix the problem i am stumped please please help
2001 Mustang GT
![]() iTrader: 2 reviews
do you hear a click? check relays, and the main fuses which power those
1990 mustang gt
Did they ever work? If so did they both stop working at the same time?
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
2000 GT 'vert
+1
#6 | |
hey i bought it from a auction i have had the car for about two weeks the locks work the fuse is good everthing else on the circut works neither one of the windows work no noise nothing i kinda wanted to convert it to manual is it complected to do |
1991 Mustang LX 5.0
This is for a 93, but I'm guessing that yours should still be the same. It's a 'five wire reversal rests at ground' system so make sure your grounds are good too. Hell, maybe both motors happen to be shot. Get a meter out and print this off and go to town.
http://www.veryuseful.com/mustang/te...werWindows.gif
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
2000 GT 'vert
converting to manual... Do they make manual windows for the mustang anymore?
1990 mustang gt
It would be more work to make them manual than to fix yours. Take of the drivers side window switches. There will be a wire that gets 12v when you press up, and another wire when you press down. Most likely its your motors though.
2000 GT 'vert
That's my thoughts..
89 GT
Depends on the regulator. If it has the input for the window crank then all you have to do is remove the drive gear from the motor. If it doesn't have it then you'll need the regulator from a manual car. They made them for those years so you should be able to hunt them down. To get the power ones to work you'll need a power probe or a multimeter. Use that diagram that faststang posted and check your wires. All of them should be ground at rest except your power input to the switch. When you push a rocker one way, you should have power on one side and ground on the other. There's a lot of things that can go wrong with a window circuit. I've seen the grounds to the switch go bad, and the power lost to the switch more often than not. Sometimes the contacts in the switch get burned out and you;ll have power and ground at the inputs and nothing out. If the switches work fine, then what I do is unplug the switches and feed power to the motor directly. There's only 2 motor wires, feed power and ground one way and the window goes up, reverse them and the window goes down. That is all the switches do, and there are no relays in the circuit.
There should also be breakers and not fuses for the window circuit. They are rectangular metal cases that plug in like a fuse and will pop if there's an issue and then reset when they cool down. Those could be bad also, but only if you're not getting any input into the switch. This may not be the case for your car, but it is for a lot of cars and I haven't worked on a window circuit on a sn-95 car in a long time, so double check your owners manual and fuse box. |
Threads Similar to: my windows dont roll down
| When I roll my windows down, I'm getting grease streaks! WTF? | Somewhere in Time | 2005 - 2010 | 11 | August 28th, 2010 06:23 PM |
| WTF? I dont know...I just dont know | dr.gonzo! | The Clubhouse | 12 | April 29th, 2010 09:48 PM |
| EMERGENCY! Windows won't roll up | WackyWormer | 96-98 | 5 | March 21st, 2010 11:28 AM |
| 2005 explorer windows dont work | 99 gt | All Other Vehicles | 7 | May 22nd, 2008 12:37 AM |
| Can i swap my 1985 1/4 rear windows/louvers for 87+ Windows? | noyz25 | 5.0 Mustangs | 2 | September 10th, 2007 12:23 AM |
