1992 Lx
11.39@119.24
No oil out of pushrods during priming
Made this thread on corral too, see what you guys think.
Priming my 347 with a cordless drill, spinning the oil pump shaft counter clockwise, but cant get oil to come out of the pushrods. Last time we primed the motor it came out quick, been spinning it this time prob 10-15 min and nothing. Thoughts?
1992 Lx
11.39@119.24
SVTfocus, F250
yeah that pump shaft doesnt look seated, i think you can only put the shaft in from the bottom.
was the drill struggling while you were priming?
1992 Lx
11.39@119.24
nope. Watch that vid, thats how easy it spins
1991 Mustang LX 5.0
I think you'll have to pull your motor back out and replace your cam bearings
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 Ford Mustang GT
I saw some thing like this on tv... and it turned out to be the position of the rotating assembly. ( meaning that in one certain spot the oil passages are blocked )they cranked it into a different position and then it would prime. i think it was just a few dagrees.
1992 Lx
11.39@119.24
Spun it to like 4 different positions and tried it, no luck. I'm 90% sure the shaft isn't in the oil pump. It spins waaaay to fuckin easy. I'm gona pull my timing cover tomorrow. Sucks fucking dick
89 GT
You're right, that is spinning way too easy. I can barely spin mine with my good 18v cordless and get oil out of the pushrods so to be able to spin it by hand like that has to be the shaft not seated, given that the pump was fine before you pulled the motor.
i'd yank it man somethings def not right
1992 Lx
11.39@119.24
Yeah figured. Pump has maybe 150 miles on it shits brand new. If I have to pull the fucking motor I'm gona burn the car. Just got it dropped in bolted up to the tranny and my headers on today. Just really hopin I can see in there/fuck with the shaft with the cover off without pulling the pan
EVERYONE STOP!!!!!!!
I ran into an issue very similar to this and I'd appreciate nobody else butting in until hatch responds. Lets start with the easy things. Did this engine just recently get built, or has it been running before? If its a fresh build, did you verify that ALL of the oil galley plugs were in place? There are three behind the timing cover, and one at the rear of the engine, up top under the PCV. (see pics) ![]() ![]() After you have verified all of the above. follow these steps. first, you have to spin the pump counterclockwise. second, you wont get oil out of the pushrods unless you are turning the engine over. The only time oil will flow through the lifters is when they pass through a certain area of the lifter bores. Put a 15/16 socket on the crank and SLOWLY turn it clockwise while you are cranking on the oil pump driveshaft counterclockwise
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
^^ dude didn't even read the thread...hahaha
Yeah pull the motor back out, either the shaft is fucked or the pump is fucked, or there is no oil in the pan... no way you should be able to spin it that easy.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1992 Lx
11.39@119.24
but I dont waaanaaaaaa, Im gona go pull the cover in a bit and hopefully be able to see in there. And theres 7 mothafucken quarts in it
#14 | |
Hatch. Dont pull the engine out. If you want to verify that the oil pump is working, just remove your oil filter. If there is oil in it, your pump is working. IF there is oil in the filter... remove your intake manifold and make sure the rear lifter valley oil galley plug is installed. When I first got my engine, it wasnt there. I too would prime and prime. and nothing would happen. I never got oil up into the heads. That galley plug ended up being my problem.
1992 Lx
11.39@119.24
figure it out motherfuckers, thanks for all the help. Oil pump shaft was in there crooked or some shit, tried to slap my dizzy on, wouldnt seat, was at least an inch too high, to the point I could spin the rotor (so the gear wasnt engaged with the cam gear) Kept fucking with it pulling it in and out, in and out, slowly, then hard, then slow again, and eventually it lined up and went bout an inch lower, stuck the drill on, bam resistance, oil out of pushrods
#16 | |
1992 Lx
11.39@119.24
1988 lx
9.68@142
you needed to make a thred about that.... you couldnt tell that it wasnt in the hole....i guess thats the story of your life.. lol
#18 | |
89 GT
1992 Lx
11.39@119.24
I dont have xray vision to see through the timing cover and the block to see it in the oil pump. Was through the hole where the dizzy goes so figured it was straight
i suppose the main question is.... how the hell did you NOT get it in there right. The shaft should have a stopper on it that prevents it from going up through the block. Did you forget to put it in from the bottom, and simply tried dropping it in from the top?
Threads Similar to: No oil out of pushrods during priming
| Priming these motors of oil..... | Tmac3320 | 99-04 | 4 | June 8th, 2010 01:45 AM |
| Which pushrods will I need to use for GT-40 | 5.0 street stanger | 5.0 Mustangs | 3 | July 17th, 2009 06:04 PM |
| pushrods | 97fordsixer | V6 Mustangs | 2 | February 3rd, 2008 11:18 PM |
| Pushrods | javier351lx | 5.0 Mustangs | 17 | September 22nd, 2007 12:41 AM |
| pushrods | mmvi | V6 Mustangs | 9 | August 10th, 2007 08:38 PM |
