1994 v6 mustang
looking to swap out the 3.8 (HELP)
can any 1 help me with letting me know what do i need to swap out my 3.8 to a 4.6 or 5.0 . dont know witch 1 yet. ford told me they would sale me a brand new 5.0 for 2000. is that good.. and if i do that what other parts would i need to get.. thanks
If i remember correctly the 3.8L mustangs had a different K-member which doesnt really work for v8 swaps. Dont know if there is a company that makes mounts to correct for it otherwise youll need to start with a whole new kmember.
1991 Mustang Gt 5.0
1+
91 Mustang Gt306/Under Drive Pulleys/gt40 heads/ so many more goodies |
Might be better to just trade up to an 4.6 or 5.0 Stang.
Eliminate the headaches. If money is an issue, then it's understandable.
Have you driven a Ford lately ?
i just got done doing the swap to mine so i can help you out i had a 1997 3.8 and i swapped it to the 5.0 just because that motor is easy to mod and a very simple motor
Youll need a lot of parts off a 1994 or 1995 5.0 mustang to do the swap motor wiring harness battery wiring harness and the main wiring harness that goes to your computer youll need the 5.0 motor bell housing fly wheel and a clutch none will work from the v6 except the starter you can use your v6 rad and electric fan youll need to get the 5.0 mass air and thats about all i needed to do mine you actually swap you v6 motor mounts onto the v8 and you put them on oppositie sides and it will mount perfect as weird as that sounds but before you do anytihng you need to look up whats trans you have or you might have to get one what k member you have or you might have to upgrade that and eventually you will have to put a 8.8 rear in cause v6 come with 7.5 mine laster me about 3 months till i blew it out but i was really hard on it so if you babied it around the v6 rear will last you if you dont have money for it right off the start So the easiest thing to do would prolly be to find a wrecked 1994-1995 mustang and buy it and just pull all the parts from it or try to find a complete set with everything you need cause piecing together can get very irritating let me know if you have any questions |
i forgot to mention that you need to see if you have the t5 trans or the t45 trans cuase the t45 trans wont mount up to the 5.0
luckily my car had the t5 trans when i got it and the v8 k memeber i was told by a ford guy that 1996 1997 1998 year v6 mustangs could be found with mis match v8 parts some had v8 k memebers some have t 5 trannys it was hit or miss like ford just put in whatever they felt like that day |
94 mustang gt
too slow to tell
you dont need to change the bellhousing if you have a t5 trans all a 3.8l is is a 5.0 with 2 cylinders cut off trust me i have a v6 trans in my 94 gt
yeah you dont have to change it if you have a t5 but if you have a t45 you will need a trans and a bell housing
1994 v6 mustang
thanks a lot bro
yeah no problem
Threads Similar to: looking to swap out the 3.8 (HELP)
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| pi swap or motor swap | whiteboy05 | 96-98 | 12 | December 8th, 2009 05:30 AM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
| 1995 351 to swap or not to swap.& how to? | Jeffery9508 | 94-95 | 9 | August 3rd, 2008 08:00 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
