Oil pressure gauge ?
I bought a c2 oil pressure gauge to put in my car
But the oil pressure send unit cant screw into the block theres not enough room for it and the side of the sending unit hits the block Has any one ran into this problem before can you get an adapter or anything to to fix this ? |
89 GT
What year is your car? They changed something on the block 94 and up. I've ran into this same problem because I had a 94 block in my car at one point and my sending unit from the 89 wouldn't fit. There is an extender you can get to make it fit I believe you can get it from ford, or you can just get the smaller fitting for the 94-95.
89 FOX/01 WS6
0@0/13.1@106
You should be able to use brass fittings to extend it so it clears.
I have the same c2 gauge in my 88 and it fit fine. Same size as the pos oem sender was but it didn't screw directly into the block. there's an adapter that should be there from the factory.
here's a pic of what im talking about.. it's the piece the wrench is on obviously
yeah i have a 1995 block the stock fitting fits in fine but the aftermarket one doesnt because its a lot bigger size around im gonna try to see if i can piece together a brass fitting and make it T so i dont have a dead gauge on my dash
ok thanks
Threads Similar to: Oil pressure gauge ?
| oil pressure gauge | 302Army187 | 5.0 Mustangs | 40 | August 16th, 2009 05:28 PM |
| oil pressure gauge | mxnate116 | 5.0 Mustangs | 1 | June 8th, 2009 09:40 AM |
| oil pressure gauge | Codeman | V6 Mustangs | 0 | May 10th, 2009 12:18 PM |
| oil pressure gauge | 88Saleen | 5.0 Mustangs | 11 | April 18th, 2009 03:02 PM |
| Oil pressure gauge | RC02GT | 99-04 | 17 | March 22nd, 2009 12:09 AM |
