intake manifolds bang for buck
Old December 9th, 2010, 06:30 PM   #1
1990 mustang lx
pusher90 is on a distinguished road
I have 90 lx 5.0 5spd with 106k miles. i have a bbk cold air intake im not sure what kind of upper n lower intake manifold. these are the parts im settting up to buy
e303 cam
1.7 roller rocker arms
24lb injectors
mass air flow
shorty headers
h-pipe no cats
flowmasters 2 chamber
130 amp alternator
327 gears
im just not sure if the ford cobra intake would work. any thoughts?
Old December 9th, 2010, 06:36 PM   #2
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Don't buy that e-cam please. Everyone makes the same mistake...Learn from someone who has a letter cam (me)..Wait until you get cylinder heads to get your cam. As far as bang for your buck intake, get an explorer intake. Take some sandpaper, and clean up the inside of it. Done
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old December 9th, 2010, 07:40 PM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Explorer since it's the same as the cobra, and don't put 24's in it until you need them... and you won't with that. Skip the E cam, not a bad cam, but there is much better unless you have to because of emissions. Don't forget a bigger throttlebody. 65mm would be just fine for that setup. And my only question is why only 3.27's? Do you drive 50 or more miles a day at 75-80mph? If you are an auto, I would do a 3.73 minimum and 3.55's with a manual.
Old December 9th, 2010, 07:42 PM   #4
1990 mustang lx
i thought a e cam was the best way to go. explorer intake? that a brand? or the suv
Old December 9th, 2010, 07:46 PM   #5
1990 mustang lx
i like the 3.27s cause im still good on the freeway. i like to drive so i dont wont the car to be working all that hard. and i have the stock 5spd. i still wnna be able too keep my high end on the freeway also
Old December 9th, 2010, 07:58 PM   #6
1991 Mustang LX 5.0
You'll be fine with 3.55's too, and it'll give you just a little more kick too. I currently have 3.55's and a 5 speed, and I'm switching to 3.73's cuz I have another rear with them in it. I drive alot, and the mileage with the 3.55's isn't bad at all. And explorer the suv, yes. Any one with the 5.0 in it. It's a cheap upgrade over stock. The heads on them are better too, for cheap, just a little fyi. The E cam is only the best way to go if you HAVE to pass emissions. But many people claim to pass with the TrickFlow Stage 1 cam.
Don't take this the wrong way by any means, but just because you didn't know about the explorer intake, I suggest researching A LOT before you buy anything. You'll want to have a gameplan or goal in mind before you start buying parts, or you'll end up buying stuff twice or more. What is your main intent with this car. Just a DD? Some dragstrip? Some autocross? And lastly, what is your budget, or are you just buying things when you can? The answers to those questions will help you on your quest for affordable, reliable power.
Old December 9th, 2010, 08:16 PM   #7
ryanw's Avatar
1991 Ford Mustang GT
+1 on that one... Hey Faststang91Lx how do you like those 3.55 gears. i have 3.27 in mine as of now but i have a set of 3.55 in my gerage waiting to go in. just wanna hear your thoughts
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old December 9th, 2010, 08:25 PM   #8
1990 mustang lx
ok all good. thats why im on here to get some info. my first mustang but i want to make him hot. so i will be buying stuff along the way when i can. but i do want to run hard n strong street and freeway.
Old December 9th, 2010, 08:33 PM   #9
ryanw's Avatar
Originally Posted by pusher90 View Post
i want to make him hot. but i do want to run hard n strong.
That sounded really gay.... im just joking bro.... lol
255 fuel pump,
3:27 gears
Old December 9th, 2010, 08:47 PM   #10
1991 Mustang LX 5.0
I have no issues with the 3.55's at all, I would consider them a good all around gear. I'm jumping to the 3.73's mainly because 1. I have them, and 2. I'm gonna start hitting the track next season. You won't notice a huge difference over your 3.27's, but if you can do it yourself or get it done cheap, I'd do it in a heartbeat. It would probably feel like you added another 15-20 horse.
Threads Similar to: intake manifolds bang for buck
Bang for my buck?? TrueBlue756 2005 - 2010 27 September 21st, 2010 01:23 PM
best bang for your buck njstang 99-04 37 August 30th, 2008 02:50 PM
Bang for your buck blackmustang285 2005 - 2010 22 August 30th, 2007 10:40 AM
Bang for your buck value WilltheThrill 99-04 90 February 2nd, 2007 01:40 PM
best bang for buck PONYBOY14 96-98 0 January 26th, 2007 12:57 AM
