Hmm... my mustang just caught on fire. - Page 2
Old December 10th, 2010, 01:23 PM   #21
dshaff36's Avatar
1990 GT Hatchback
dshaff36 is on a distinguished road
Originally Posted by xxvicarious View Post
Fired it up, letting it warm up. Turned on the lights, all was working find. Theeeen my gauge cluster lights cut out, and smoke starts billowing from the driver's side of my dashboard...
wtf?
Something obviously got hot enough to literally catch on fire....That was a lotttttt of smoke. Call it stupid, but instead of having my NEWLY PAINTED FOXBODY (Yea, it just got painted today) burn to the ground, I grabbed the hose, and jammed a few bursts of water up by the headlight switch. Heard a sizzle, and the smoke eventually cleared out of the car.
W......T......F? Im gonna take a look at the damage tomarrow morning, but if anyone knows what can cause this right off hand, please. FILL ME IN.
I don't see anywhere where the OP asks to hear everyones fire stories! (although I enjoy reading them) I'm sure carious would appreciate it if everybody focused more on figuring out what went wrong in his situation. So lets try to get back on track a little guys.
For now, I am thinking it is a physical problem with either the contacts or a wire itself. If I can see some pictures of which wires are mostly melted and the back of the cluster I would be able to tell more.
Old December 10th, 2010, 04:14 PM   #22
1985 Mustang GT
12.89@107.72
xxvicarious is on a distinguished road
Send a message via AIM to xxvicarious Send a message via Skype™ to xxvicarious
It fired right up this morning. I flicked the headlight switch real quick. All the lights are working, except the cluster lights of course. And no fire. The inside of my car smells like a meth lab, now. Awesome
Pic isnt working. When I dropped the cover, one of the fuses was melted. Found a washer jammed where a fuse should go. Its corroded in, and wont come out. Awesome
Old December 10th, 2010, 04:57 PM   #23
1985 Mustang GT
12.89@107.72
Just pulled the headlight switch.
Wires:
Light brown/tan with white stripe = Melted.
Light blue with red stripe = a little melted.
Im GUESSING the brown/white is to the gauge cluster lights.
And Im GUESSING Blue/Red is to the running lights. It LOOKED like
they were off when I pulled the blue wire out. But theyre so dim to
begin with, its hard to tell, even mashing my face against the taillight
with a hood over my head.
Ill see if I can find out what they actually are. The switch seems to be fine.
No corrosion, a little dusty. MY GUESSSSS would be: for some reason, the fuse
went to blow. What puzzles me is one of the fuses, the plastic melted off, but it
didnt blow. The little wire inside the fuse is still intact.
Im puzzled. I hate wiring and electronics.
Old December 10th, 2010, 06:21 PM   #24
1985 Mustang GT
12.89@107.72
Just looked at the back of the fuse box. Everything involving lighting is just toast. I dont know how my headlights and running lights are still working, the wires are fried and exposed. Is there any way to wire headlights and running lights to a switch? I have to drive at night, I really dont have an option or the patience to rewire everything. fml.
Old December 10th, 2010, 07:09 PM   #25
Rascus's Avatar
Rascus is on a distinguished road
I would say do it the right way now, and avoid putting yourself in the same situation (fire!) later...
Old December 10th, 2010, 10:03 PM   #26
dshaff36's Avatar
1990 GT Hatchback
Thats a lot to deal with, I'm sorry man. I don't understand how so many different things would go wrong at the same time unless you were sending a lot of extra voltage through the system. That sounds like something that probably needs to be looked at by someone who really knows a lot about the car's wiring. It would be hard to tell what is wrong without seeing it in person. I say take it to a shop and get them to look at it and fix it in a way that it won't happen again. Sorry I couldn't be of anymore help!
Old December 11th, 2010, 12:08 AM   #27
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
I agree, take it to someone who knows what there doing, but it might get costy if they rewire the whole thing.
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old December 11th, 2010, 04:24 AM   #28
1985 Mustang GT
12.89@107.72
If you knew where I lived, you'd know Im probably better off doing it by myself, dead serious. If someone could just tell me which wire out of the three wires connected to the low beams is power(needing a 12 volt source to it to power the light), that would be more helpful than you know (color of the wire, and color of the stripe). Im just gonna have to wire it to a switch, and stick a 20 amp fuse in a break somewhere for now, until I can afford a Painless Wiring Kit. Just that
one answer would help so much.
Old December 11th, 2010, 09:24 AM   #29
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Buy an electrical meter. That will answer all your questions for you. Even a 10 dollar cheap one will work just fine.
Old December 11th, 2010, 10:44 AM   #30
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
HMERacing is on a distinguished road
+1
I rewired my 89 myself. I reused part of the lighting harnesses, stripping them down to just the wires nec. The rest I made a Fused Relay panel and used a Painless switch panel. It was time consuming but pretty simple.
I Rewired headlights hi/lo, turn signals, Tail lights/ brakelights, reverse lights, parking lights, lic. plate light, Cluster lights, dimmer switch, cluster turn signal lights and high beam indicator, voltage guage and a few others.
I used my Multimeter and a couple wiring diagrams for reference. The diagrams I found did not match up perfectly to my harness but it was a little help.
Good luck!
Mike
1989 Mustang LX, 2001 Transam WS6
Originally Posted by 302Army187 View Post
I'm going to install an U pipe.
bitch is going to re route the exhaust pulse back out of the intake between intake pulses.
Threads Similar to: Hmm... my mustang just caught on fire.
How to escape your mustang in the event of a fire. Imran The Clubhouse 27 April 16th, 2010 12:56 AM
99 Mustang - Stumble, Miss fire problem? Nitmare67 99-04 9 March 23rd, 2010 05:35 PM
Car caught on fire a couple of weeks ago baine21225 5.0 Mustangs 5 December 14th, 2009 10:20 PM
Burnont from a Lightning Mustang makes Fire 330CubeGt Videos 2 July 15th, 2009 03:18 PM
Hmm i think ive seen this mustang before... Vinyl66 The Clubhouse 1 October 22nd, 2007 09:23 AM
