Hmm... my mustang just caught on fire.
Old December 9th, 2010, 11:01 PM   #1
1985 Mustang GT
12.89@107.72
xxvicarious is on a distinguished road
Send a message via AIM to xxvicarious Send a message via Skype™ to xxvicarious
Fired it up, letting it warm up. Turned on the lights, all was working find. Theeeen my gauge cluster lights cut out, and smoke starts billowing from the driver's side of my dashboard...
wtf?
Something obviously got hot enough to literally catch on fire....That was a lotttttt of smoke. Call it stupid, but instead of having my NEWLY PAINTED FOXBODY (Yea, it just got painted today) burn to the ground, I grabbed the hose, and jammed a few bursts of water up by the headlight switch. Heard a sizzle, and the smoke eventually cleared out of the car.
W......T......F? Im gonna take a look at the damage tomarrow morning, but if anyone knows what can cause this right off hand, please. FILL ME IN.
Old December 10th, 2010, 12:11 AM   #2
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
Take off the gauges and check. Unplug the battery too
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old December 10th, 2010, 12:17 AM   #3
1985 Mustang GT
12.89@107.72
Uhooked the battery right after it happened, I'd hate to wake up tomarrow to a smoldering hunk of plastic and metal in place of what used to be my 'stang.
Its an '85 GT, are the gauge clusters easy to pull? Or does it requiring pulling more than just the cluster?
Old December 10th, 2010, 12:20 AM   #4
warrior86's Avatar
2008 Mustang GT
warrior86 will become famous soon enough
Send a message via AIM to warrior86 Send a message via MSN to warrior86
glad you took immediate action. That sucks!
'91 Ford Escort LX - SOLD
'81 Chevy Corvette - SOLD
'94 Toyota Celica (Supra) - SOLD
'97 Ford Mustang - R.I.P / SOLD
'07 Ford Mustang V6 - "Dad's Ride"
'08 Ford Mustang GT - \m/ Rocking \m/
Old December 10th, 2010, 02:22 AM   #5
Firaga's Avatar
1993 Mustang GT
Firaga is on a distinguished road
Mine caught on fire right as I pulled up the the driveway. The lights had been dimmer days before, and the voltage was really now. All of a sudden one I gave it a lot of gas up my hill BOOM FIRE.
My alt went up. Turns out one of the wires running to/from the alt (I think it was a ground, I don't know jack about electrical) had been rubbing against that plastic piece that covers the fuse box, and sliced open the wire, hello fire!
I sprayed it down with an old extinguisher, and to this day (almost a year ago, I STILL find extinguishing agent in the engine bayl
I have a 93 5.0
I love my car, and all my friends hate it.
AEM Brute Force intake, BBK 75mm TB/EGR, C&L 75mm MAF, Trick Flow Street Upper/Lower, Custom exhaust with Dynomax SuperTurbos, Tokico Rear Shocks
Old December 10th, 2010, 03:11 AM   #6
dshaff36's Avatar
1990 GT Hatchback
dshaff36 is on a distinguished road
Hmmmm, that is really weird. Sorry that happened to your fox, hopefully it didn't damage anything but the wires. Nothing was changed with the car besides the paint since you last drove it right? I don't know what could have caused it if it drove fine before the incident. Your best bet is to follow the melted wires and see if you find anything exposed (other than the melted parts of course).
Old December 10th, 2010, 08:50 AM   #7
1985 Mustang GT
12.89@107.72
Thanks for the help. Ill definetly check out the grounds. Im sitting on the couch waiting for the sun to come up just so I can go look at it haha. And to answer the question, yes, All I did was paint the car, no wiring was relocated or changed or disconnected/reconnected during the painting. Like I said, my gauge cluster went out, then the smoke started. Headlights were still on, running lights still work. Even after I blasted some water under the dash, I waited an hour, and pulled the headlight knob, expecting either a fire again, or nothing to work at all due to water damage... But the only thing that didnt work was the gauge cluster, so hopefully the damage isnt too bad.
Headlights work, running lights work, car still starts.... Ugh.
Ill take pics as soon as I can. And pics of my 90% completed paintjob haha.
Old December 10th, 2010, 09:25 AM   #8
nolife's Avatar
91GT, 88GT, 02GT
It could be a previous owners rig job for wiring but.. the headlight switch and the 2G alternator pigtail are common flame ups in Fords made in that time frame. The contacts get a little bit of corrosion, that leads to a higher resistance. The higher resistance leads to heat, the heats leads to even more corrosion and deformation which leads to more heat which eventually leads to failure or worst case, smoldering and fire.
Old December 10th, 2010, 09:29 AM   #9
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
had the same thing happen to my pulling truck this summer, had to jump out and yank the cable off the battery
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old December 10th, 2010, 11:26 AM   #10
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
should invest in a fire extingisher. I've had one in the back floorboard for a while.....
Glad the hole car didn't go up in flames. hope its nothing to crazy where you have to rewire everything.
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old December 10th, 2010, 12:18 PM   #11
dshaff36's Avatar
1990 GT Hatchback
Yes pictures should help everyone in figuring out what caused it. Hopefully its just some bad contacts on the 12v input to the cluster.
90% completed...as in fire damage? Or was it just not complete before?
Old December 10th, 2010, 12:27 PM   #12
2002 Chevrolet Camaro Z28
Buffalo02Z28 is on a distinguished road
Mustangs just spontaneously catch fire?
Old December 10th, 2010, 12:28 PM   #13
Tony Silva's Avatar
1991 convertible GT
Tony Silva is on a distinguished road
Um, So how long before the fire did your cluster go out? Cause my cluster went out like... a week ago!!!!!!!...Is my Fox about to have a melt down? Damn!
Old December 10th, 2010, 12:29 PM   #14
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
WOW.. same thing happened to me in a VW about 20 years back.. but I was nowhere near any water / fire extinguisher and by the time I was able to even pull off the road and get out of the car, the entire dash was engulfed in flames follow by the engine and it was over.
Glad you got it stopped quickly!
Along with any other vehicle that bad wiring (my car didn't have a radio and was purchased within a week from someone else. My guess is someone else screwed up some wiring.)
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old December 10th, 2010, 12:30 PM   #15
2002 mustang gt
12.2 at 117
yes bacasue they are fast.......
un like chevys
Old December 10th, 2010, 12:38 PM   #16
Tony Silva's Avatar
1991 convertible GT
One time my dad was driving his aero coupe Grand Prix down a hi-way to a small town called Durham....some how a fire started in the engine compartment...so my dad pulls over, and a passerby calls 911.......The entire Durham Fire Department responds to the fire!!! LOL....The ENTIRE fire dept consisted of one volunteer fire fighter senior citizen and an old ass busted up truck.....Im talking a 1940 truck and some elderly gentleman in his (late) 70's.......I didnt know what an aero coupe was at the time but I guess they are kinda rare. I thought it was just an ugly car with a bastard hatchback stuck to it.
Old December 10th, 2010, 12:43 PM   #17
Tony Silva's Avatar
1991 convertible GT
Needless to say, but the car burnt to the ground. It burned so hot that the door handles literally melted off the car and pooled onto the ground. ....gotta hand it to the old fire fighter though....It was a losing battle but the old guy never gave up.....kept sayin "We'll save some of her"
Old December 10th, 2010, 12:53 PM   #18
nolife's Avatar
91GT, 88GT, 02GT
Same here in both of my foxes and my Bronco. You never know.
Costco has 3 pack of these for about $20
Amazon Amazon
Old December 10th, 2010, 12:58 PM   #19
1987 ford mustang
87fourbanger is on a distinguished road
Ha I can imagine that , last week I drove by. A burning camaro. I madesure the driver was safe and all but I wasn't worried about the car. ...after all its a chevy
Old December 10th, 2010, 01:08 PM   #20
Tony Silva's Avatar
1991 convertible GT
Gonna check out Costco later on today for those fire extinguisher cans. Not too sure if I want to be that close to the fire though...(
Threads Similar to: Hmm... my mustang just caught on fire.
How to escape your mustang in the event of a fire. Imran The Clubhouse 27 April 16th, 2010 12:56 AM
99 Mustang - Stumble, Miss fire problem? Nitmare67 99-04 9 March 23rd, 2010 05:35 PM
Car caught on fire a couple of weeks ago baine21225 5.0 Mustangs 5 December 14th, 2009 10:20 PM
Burnont from a Lightning Mustang makes Fire 330CubeGt Videos 2 July 15th, 2009 03:18 PM
Hmm i think ive seen this mustang before... Vinyl66 The Clubhouse 1 October 22nd, 2007 09:23 AM
