need help with these codes
Old April 13th, 2007, 11:07 PM   #1
chadjones99's Avatar
chadjones99 is on a distinguished road
I have a 86 mustang that has been converted to mass air
I have taken out the emission equipment , and AC
I have these codes and I have looked them up but do not under stand them
looking for a little help. also I did have a to lean code but have replace the bottom wiring harness and O2 and this has fixed that.
also car runs fine
codes are :
81,82,85,95
I have heard with the conversion was not done right you will get the fuel pump failure code .
thanks
chad
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion
Old April 13th, 2007, 11:13 PM   #2
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
homebrewed is on a distinguished road
81: Thermactor air bypass (TAB) circuit fault
82: Thermactor air diverter (TAD) circuit fault
85: Canister purge (CANP) circuit fault
95: Right air always upstream
That kinda what you had in mind? Or do you need to know what they mean?
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old June 20th, 2007, 01:37 AM   #3
1st fox body is on a distinguished road
Got an 86 GT too . I just did the MAF CONVERSION . Got some problems in the 1200 to 1750 RPM RANGE . I hooked back up all the smog stuff for now . It got rid of all the codes except for the [542] fuel pump secondary . Anyone got any ideas?
Old June 20th, 2007, 01:57 AM   #4
TENGRAM is on a distinguished road
Re: need help with these codes
also car runs fine
codes are :
81,82,85,95
thanks
chad
81 and 82 = your solenoids that mount to the back of the passenger side strut tower are missing.
85 = the solenoid that purges your charcoal canister is missing
95 = fuel pump circuit failure...as you said, probably because of the MAF conversion
edit: just realized how late i am
89 GT t5 3.73
www.my5oh.com/
Threads Similar to: need help with these codes
woo hoo more CEL codes mikethetigerrr V6 Mustangs 10 August 22nd, 2007 02:42 PM
Codes 8A_Honda 5.0 Mustangs 0 August 16th, 2007 09:06 PM
CEL came on. Codes JASonic The Clubhouse 2 July 27th, 2007 06:57 PM
Too many codes. Need help..... bad!!! 88Horseman 5.0 Mustangs 1 October 22nd, 2006 04:47 AM
Ran Codes 94, 44, And 33 hmotes 5.0 Mustangs 3 October 3rd, 2006 08:20 PM
