weird check engine problem...
Old April 14th, 2007, 04:38 AM   #1
fastford3388's Avatar
1991 Mustang GT
fastford3388 is on a distinguished road
Send a message via AIM to fastford3388
I've got a very strange problem with a check engine light and need some advice. I've got an '89 gt and I had 7 codes when i bought the car and it wouldn't idle without stalling out. the codes included: TPS, EGR position sensor, and a speed sensor. I've fixed all of those things and cleared the codes. Now when I check my codes the read out reads "no codes" but the engine light stays on. The strangest thing about this is that at wide open throttle, the engine light goes off and i feel a boost of performance. Also, sometimes I do smell gas/exhaust when I am idleing at a light but that could be because my exhaust dumps off after my mufflers. any one have any suggestions on what it could be? i was thinking a vacuum leak but I am not sure.
- '90 Mustang LX-Sold "Debbie"
- '89 Mustang GT- Deceased "Lucy"
- '91 Mustang GT-70,000 mi "The Unicorn"
Old April 14th, 2007, 09:16 AM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
could...not saying is....could be ecm problem. try using a reader that allows you to monitor sensors and various readings.
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old April 14th, 2007, 11:48 AM   #3
Dr.Watson is on a distinguished road
yea my lx wouldn't pull codes, bad ecu
Old April 14th, 2007, 05:20 PM   #4
angermgt's Avatar
angermgt is on a distinguished road
i also have 89 gt. had a rough idle and sometimes stalled. it turned out to be idle air controller(a cylinder looking thing located on the front of the throttle body)take it off (2 little bolts) and clean the ports on tb and air controller with carb cleaner. its quick. cant hurt.
Old April 14th, 2007, 05:58 PM   #5
tording92lxnotch is on a distinguished road
are you getting no codes with the KOEO test and the KOER test? In order for the tester to even run the codes for the KOER test you have to have all the codes cleared from the KOEO test. If they truly are throwing no codes then you will get a code 11 which means system passed. If this is the case and you still have a light then you have an electrical issue or your ECU has something going on with it.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old April 14th, 2007, 10:57 PM   #6
1991 Mustang GT
but the weirdest thing is that at Wide open throttle, the light goes off and when i slow down, it comes back on. the IAC shouldn't do that because the IAC only works when the car is idleing. How can I tell if i have a bad Engine computer? could the fact that It used to be a 5 speed and now it's an AOD have any thing to do with it?
Old April 14th, 2007, 11:09 PM   #7
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
tranny swap shouldn't be an issue I don't believe because the computer doesn't control shifts, etc... I might try disconnecting the o2 sensrs one at a time( just the connections if u can reach) and see what happens. did u pull the negative cable for a few minutes to reset the ecu?
Old April 15th, 2007, 04:18 AM   #8
1991 Mustang GT
i have stored the car over the winter with no battery. I'm not getting an O2 sensor code.
Old April 15th, 2007, 10:16 AM   #9
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
o2 sesors control the operating loop of a computer... when they're warm and working properly the ecu goes into closed loop- when they're inop it stays open loop -in a preprogrammed air fuel ratio- which is rich -therefore when you're at wot- that is also preprogrammed air fuel... my thought u might get lucky and find a faulty 02 sensor, or like was said your ecu is fried... but ur code goes away at wot tellin me that operating parameters other than the ecu preprogrammed air-fuel is acting up... its worth a shot...
Old April 15th, 2007, 05:10 PM   #10
I could be wrong, but wasnt the aod an electronic od wherer the computer signaled the trans to shift in and out of od?
Old April 15th, 2007, 05:13 PM   #11
I think you may be correct on this. I have always read/heard that you can use an Auto ECU (A9P) with a manual car but you can not use a manual ECU (A9L) with an Auto car. The ECU controls the tranny and the manual ECU is not setup to do this so you get some funky things going on.
Old April 15th, 2007, 05:24 PM   #12
in which case that MIGHT or MAY NOT explain the ck engine light on/off at wot and not...but doesnt explain why no code. need to try to read koer codes and see if it shows up or find a way to monitor data while driving
Old April 16th, 2007, 01:08 AM   #13
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
I have an aod out of my 92...there are aode and aod. I guess it would depend on the tranny your prolly right.
Old April 16th, 2007, 02:11 AM   #14
1991 Mustang GT
I'm almost positive i have an AOD not an AODE. How can I tell? the car also smells like it could be running a little ritch. Could this have any bearing on why the check engine light is on?
Old April 17th, 2007, 08:52 AM   #15
nateo's Avatar
nateo is on a distinguished road
how do you know how to tell if a ecm is bad?
Old April 17th, 2007, 06:33 PM   #16
I used to hear in the past from several ford 'techs', that more than 3 active codes indicated a bad ecm...couldnt ever verify if statement is correct except to install another ecm to test
Old April 17th, 2007, 07:24 PM   #17
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
yes it could have a bearing... again it sounds to me that it may be an o2 sensor or both because on start up your ecm has a preprogrammed air/ fuel ratio until it warms up then the o2 sensor(s) give the ecm their reading based on a 5 volt reference. I think its the o2 sensor(s).
Old April 17th, 2007, 07:25 PM   #18
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
It can be impossible to diagnose sometimes. There is no set standard that I'm aware of to tell if one is bad or even any tricks... Like fanatic said replace and see.
Old April 17th, 2007, 07:36 PM   #19
1990 GT Convert
ken5_0 is on a distinguished road
Bad 02 or bad TPS is my guess.
Old April 17th, 2007, 08:05 PM   #20
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Pull the codes again. Might also be the EGR cause its only used at part throttle and is inoperative at WOT.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Threads Similar to: weird check engine problem...
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
Weird Acceleration Problem TheLocalGypsy 5.0 Mustangs 4 August 20th, 2007 12:27 PM
My Check Engine Problem Need To Fix This Weekend Urgent OcOnnor220 99-04 1 February 23rd, 2007 03:13 PM
My Check Engine Problem OcOnnor220 99-04 9 February 8th, 2007 01:36 PM
check engine problem ibanez570x 99-04 12 January 13th, 2007 03:13 PM
