NITROUS questions
Old April 14th, 2007, 10:16 AM   #1
rkloehn is on a distinguished road
NITROUS questions
ive heard that after you spray a car you have to shut down and pull the plugs. does anyone have any information on what i am talking about i might not know what im talking abvout though. what is the correct way to spray a car?
Old April 14th, 2007, 10:51 AM   #2
RIP Justincredible! God Speed
Justincredible's Avatar
Justincredible is on a distinguished road
Re: NITROUS questions
I am always amazed at the endless misinformation that surrounds nitrous.
This is not true.
As long as you follow the instructions provided by the nitrous kit manufacture...you will be fine.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old April 14th, 2007, 01:57 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Depends on how much you spray. If you are using a small amount of nitrous (150 or less) its kind of hard to screw anything up. Anything more than that and you do need to shut the car down and check your plugs or you are just asking for trouble. If you don't read your plugs you will never know if anything is going wrong. All it takes is a small particle of dirt to melt an engine down.
Old April 14th, 2007, 06:04 PM   #4
TurboLX's Avatar
1988 Mustang LX Turbo
hahaha!! did your little ricer honda buddys tell you this??
Old April 14th, 2007, 06:18 PM   #5
tording92lxnotch is on a distinguished road
I agree, with a small shot 150 or less you don't need to check each time. With a bigger shot like a 200 or more though it obviously would be a good idea to check it out and see whats going on.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old April 15th, 2007, 10:48 AM   #6
Stangzilla's Avatar
Stangzilla is on a distinguished road
The others are right about pullin your plugs with shots over 150hp. Reason being is you are lookin for signs of detonation on the plugs to tell if you are running to lean.. Usually if you are experiencing detonation you will maybe see some sort of metal specks on the ceramic below the center electrode tellin you to get more fuel and or retard the timing more right away..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Threads Similar to: NITROUS questions
more nitrous questions TTownZilla 99-04 63 September 7th, 2007 04:57 AM
nitrous questions gtdan 96-98 4 August 27th, 2007 08:46 PM
Nitrous Questions MustangMatt96GT 96-98 9 May 23rd, 2007 06:53 PM
Nitrous questions foxstang 5.0 Mustangs 21 March 17th, 2007 11:10 AM
Nitrous questions foxstang 5.0 Mustangs 16 March 12th, 2007 09:29 PM
