Which wire to control power window or locks
Recently installed powers doors and windows in replace of manual doors. Plugged in all harnesses, doesn't work. Which wire do I tap into to run a relay or a fuse ?
Thanks, Ted |
My Stallion is Bigger!
Well, Ted, considering power windows utilize a three position switch it is not realy a big deal, where you get it but more in where you send it. The power side uses a two sided switch with a constant ground. Directed to one side to go up and the other to go down. I would check the ground side first and then the supply side.
Ok, so your saying that the main switch has a constant ground. But what side is the ground, what side is the supply ?
Thanks |
Threads Similar to: Which wire to control power window or locks
| power door locks | terribleonexx88 | 5.0 Mustangs | 4 | July 30th, 2007 11:49 PM |
| power locks/windows | Philly | Audio/Video | 4 | July 28th, 2007 04:43 AM |
| Power Locks | crashnebula | Audio/Video | 5 | March 22nd, 2007 01:16 AM |
| power locks and windows | bcp5008 | All Other Vehicles | 3 | November 24th, 2006 03:41 PM |
| Power Door Locks | ayyubam2002 | General Tech | 0 | October 30th, 2006 12:30 PM |
