Setting rev limit on MSD box?
Where do I need to set my Rev limiter at on my MSD box? 6K 7K 8K?
depends on where hp peaks.
Dont really know?
well for some help i have 475 rwhp and my box is set with the 6k pill.i could go higher but the safe way is usually the best way.take the car out and hammer it. find an approximate rpm where it stops "pullin" and thats where i would put it, anything over that is just slowin you down. its probably right around 5500 depending on mods(cam, intake, heads,etc.)
Some info about your car would help us to better help you. If its stock heads/cam/intake then I doubt the car is making power much beyond 5k. If you have upgraded all the previous stuff I mentioned then it could be 5700 or 5800 or even 6000. As already said you don't want to rev past where your car stops making power because its just slowing you down.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller 13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock |
it has been converted to a 650 Holly carb ,eldebrock victor jr intake, msd distributor,msd 6al, msd coil, after market plug wires
#7 | |
Re: Setting rev limit on MSD box?
Oops I just read its a carbed car.. I doubt that car makes power past 6k.. Prob less...
I would put the 6k pill in it for now and go get it dynoed. Find out where it stops making power and then change it. With that setup is not making power over 6k for sure so you will be safe at 6k.
Well its not for sure to say that he will be safe at 6k. If the car stops makin power at say 5500 then if for example the power drop is due to the valves floating. If he revs it to 6k all the time there could be an issue with some valvtrain breakage.. I would put the 5.5k in it until you get it tuned then bring a 6k and a 6.5k and see what one you need.
I would hope he doesn't have valve float at 5500, even a stock 5.0 factory limiter is 6250 yet I wouldn't recommend revving that hight but yes if you do then to be extra safe 5500 would be better yet. You really need to find out where it stops making power is the bottom line.
Yeah if you have stock heads.. I dont know what you have just tryin to keep you on the safe side until you get it tuned... But yeah you are right about the 6250rpm limiter on a stock injected motor. Even though that motor stops making power way before that..
get in and hammer it see where it falls off!
490whp/432wtq, V2 13lbs. boost, 3.33 pulley |
DYNO IT. YOU'LL FIND UR PEAKS THEN.
48.47@ 12.58
Damn you fox guys are old..
you need to take pills in order to go fast j/k..i love the foxes! i miss my 86 4eye
Threads Similar to: Setting rev limit on MSD box?
| Speed Limit On GT | thewayshemoves | 99-04 | 38 | November 14th, 2007 06:30 PM |
| Motor Limit | Mach Boy | 99-04 | 26 | October 27th, 2007 12:44 PM |
| New Engine...Sky is the limit | marcfiebka | 99-04 | 46 | July 30th, 2007 05:38 PM |
| top speed limit law?? --or something like tht | orlyr21 | V6 Mustangs | 40 | January 1st, 2007 11:33 PM |
| raising rev limit | FastBack71 | Modular Mustangs | 3 | December 29th, 2006 03:11 AM |
