Look Ma! My First Post!
vibrations
i have a 89 5.0 5 speed with heads.. cam.. 70mm throttle body... cold air intake... intake manifold.. 4-10 gears... and full exhaust and long tube headers... and rebuilt engine and new transmission... clutch.. flywheel... and pressure plate...
wen the car is in neutral.. and u hit the gas and hits 3000 rpms... the car vibrates like the transmission raddles... I change the harmonic balancer... aluminum drive shaft and new u-joints... i change the wires.. plugs.. and roto-cap... and it still vibrates... tranny mounts n motor mounts also... Even wen the car is driving... once it hits 3000 rpms n up.. it still vibrates... Im loosing my mind.... why wont it stop vibrating... help me out if you know anything... thanks!! |
check tires andrims
if it does it in neutral that eliminates everything from trans back. sounds like it could be flywheel if you say sound is coming from tranny area.if not crank.
could be driveshaft with a dent, a ton of things... try looking at motor with a buddy revving it to 3k on jack stands and investigate safely...
#5 | |
Well if you said you put in a second balancer that you know is good like the other dude said it could be the flywheel.. Are you sure you have the motor balanced correctly.. If it is balanced for 50oz are you positive both the balancer and flywheel are 50oz or if it is balanced for 28oz are you sure they are both 28oz? If you are then the only thing it prob could be is something inside the motor itself... Hope not though for your sake..
#7 | ||
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller 13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock |
#8 | |||
Thanx man...
#9 | ||
Threads Similar to: vibrations
| Really bad vibrations | mustangchris | 5.0 Mustangs | 5 | October 7th, 2007 07:20 PM |
| My whole car started shaking... Really bad vibrations ??? | 1911A1 | 5.0 Mustangs | 8 | February 28th, 2007 10:13 AM |
