Battery Relocation
Old April 15th, 2007, 10:00 PM   #1
90Stang's Avatar
2005 Mustang
12.9@109
90Stang is on a distinguished road
Send a message via AIM to 90Stang Send a message via MSN to 90Stang
Battery Relocation
ok i relocated the battery to the back and now my car seems like it has a hard time turning over and sometimes it wont turn over. should i just put a better battery in it. also do i need to run the wire from the alternator directly to the battery or can it just stay on the soleniod under the hood.
Old April 15th, 2007, 11:24 PM   #2
Racinjason81 is on a distinguished road
check your battery voltage and CCAs with a tester .Also make sure your
ground is tight and makes a good connection
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old April 15th, 2007, 11:47 PM   #3
Mudv216 is on a distinguished road
its not a solenoid either it is a regulator. i had problems with mine thats the only way i know. also make sure you engine has a good ground by getting your ohm metter out and making sure that from the bellhousing to the chassis has zero ohms or that the sound indicator beeps. Good luck bud
Old April 15th, 2007, 11:53 PM   #4
90Stang's Avatar
2005 Mustang
12.9@109
i think my battery needs to be bigger. because it only does it when the car is warm and someone told me that when the starter is hot it will take more to turn it over. if the car is cold it starts right up.
Old April 15th, 2007, 11:58 PM   #5
fogged306's Avatar
89 GT
Could be the starter too. When a starter is getting weak, it will be hard to start or not start at all when it gets warm. Also depends on the type of headers you have. If they are really close to the starter, they could be transferring excess heat to the starter causing it to seem like its dying when its hot.
Old April 16th, 2007, 12:10 AM   #6
nolife's Avatar
91GT, 88GT, 02GT
The voltage regulator on the Mustang is built into the alternator. The device on the firewall that the battery + lead attaches to is the solenoid.
Old April 16th, 2007, 12:23 AM   #7
nolife's Avatar
91GT, 88GT, 02GT
In my opinion..
If this just started to happen when you moved the battery, it may be a combination of things. Typically when a car is hard to start when hot, it is the starter. Your starter may have been this way for a while but when you moved the battery, the extra length of cable reaching to the front may be a little to much for the battery to start the hard to turn hot starter ( in technical terms, the extra length of wire looses more voltage causing the starter to see less voltage which means it will not turn as easy). Basically, making the problem of a weak hot starter worse. I think you need to check three things, the first two being a free check. The battery and the wiring to the front. The battery can be checked at Autozone or similar for free and you can check your electrical connections to the front. If both of those are good then it is the starter. I had the same hard to start issue on my Mustang. I thought it was heat because of the headers and I through it was the battery. I turned out to be the starter. I paid $50 for a rebuilt one from Joe Blows local auto store and have not had a problem since.
Old April 16th, 2007, 12:27 AM   #8
Stangzilla's Avatar
Stangzilla is on a distinguished road
Usually when that happens its the starter thats the prob..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old April 16th, 2007, 12:42 AM   #9
then whats the external solenoids function off the alternator?
Old April 16th, 2007, 01:12 AM   #10
nolife's Avatar
91GT, 88GT, 02GT
The solenoid is a big switch to give power to the starter when you start the car. A solenoid would never be physically attached to the alternator. It is also used as a tie point for the other things that need a connection to the positive side of the battery, that is what all the other connections are that are attached to the same lug on the solenoid that the + battery terminal is attached to. I do not have my book in front of my but the little wire on the top middle (blue with red stripe I think) is the signal from the ignition switch that goes through the clutch safety switch to trigger the solenoid to shut and give power to the starter. I think I saw that you had an 84, it may be a different setup. You may be thinking about a solenoid that is attached directly to the starter, a lot of GM's have that design but Ford keeps it seperate and on the fender well.
Old April 16th, 2007, 01:46 AM   #11
mine has 3 wires coming off of it how many thngs can be tied down to that? do i even need it?
Old April 16th, 2007, 07:31 AM   #12
JBIGBOOTSY's Avatar
1990 LX hatch
It has no purpose, take it off, you don't need it at all.
Threads Similar to: Battery Relocation
Hatchback battery relocation pyrofenix 5.0 Mustangs 7 June 26th, 2007 02:40 AM
battery relocation with second battery onewinner 5.0 Mustangs 1 May 30th, 2007 11:30 AM
battery relocation onewinner 5.0 Mustangs 13 May 29th, 2007 03:17 AM
Battery Relocation 98vortech Modular Mustangs 0 September 14th, 2006 06:23 PM
Battery relocation quiestion? Mustang8719 5.0 Mustangs 13 May 1st, 2006 11:08 PM
