LinkBack (1) | Thread Tools |
#1
1991 GT
No idea yet
I've Got a Good One for your coil spring experts!
First off, hello- (I had a slight issue getting logged in for a few days, but the mods did me proud)
I'm over in Ohio and finally bought my first Mustang-A rust free 91 GT. It has some mods and it's no wonder these cars are so popular. Man, this is a fun car. Now on to the question at hand: The car had hit a curb before I bought it. I changed the K frame & spindles with other stock units. I've also replaced everything under the front end. lower control arm bushings, ball joints, struts- everything. (I used an energy suspension master kit and will do the rear suspension when I get the front done) Getting the Stock front coil springs out was no problem, I used an outside compressor and a jack. After sandblasting and painting everything & re-installing the K, I cannot get those stock front springs back into my fox. I've searched for 2 days and have read everything about it that I could find. It seems the way to go is use 2 jacks and slowly, carefully raise the lower control arm "ears" back up into the K frame pivot locations. Ok- I get that part. BUT, here's the catch- The engine and trans are OUT of the car. The front end is very light and it raises up the body when I jack the lower control arm back up into place. I didn't fully commit to jacking them up because if you have the jack close to the center of the lower control arm, it lifts the car body. I moved the jacks back to the pivot ears, but didn't go any further. Will it work without the motor & trans in the car and more importantly- How in the heck am I supposed to get them back in? I don't want to cut them or use lowering springs on the car at all. Mustang Suspension Gurus with your infinite wisdom- Please help me solve this. I thank you whole heartedly, in advance.
1992 Lx
11.39@119.24
go rent some spring compressors
#3 | |
1991 GT
No idea yet
2007 mustang
Not a great start, a "dumb" answer for ya would put the spring compressor on and use the jack or rig the car up where it can't lift up with the jack, ie strap it down
pearl redfire metallic 98 gt, Teksid 2valve, ported pi heads, long tubes, slp lm1, tremec 3650, 8 lb flywheel, mgw, 4.10s...
1991 GT
No idea yet
Well, no reall harsh offense meant. But when someone posts with no punctuation and a really general vauge comment, I get a little miffed. I'm not a typical "do it yourselfer", it's just that this task requires fox body experience that I do not have. I've been wrenching on cars & trucks for 25 years and done this on other cars but never had this problem. Don't take it the wrong way.
Place jack under a arm
Jack up so jack has slight pressure on a arm unbolt strut from spindle jack a arm up and hold spring spring cup once installed bolt the strut back up |
1990 mustang gt
That's how I did it when I put my springs back on.
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
#8 | |
1991 GT
No idea yet
91 Mustang GT
1991 sliver GT
1990 mustang gt
Do you have the shocks on? Why do you have to compress the spring so much, you said you can compress it up to halfway? Isn't that more than enough?
1992 Lx
11.39@119.24
go find a new forum we're all idiots and cant do springs on these cars
1991 GT
No idea yet
Yes, the strut is on. The tie rod is on. Sway bar is off. By halfway, I meant that halfway to where it needs to be, to line up the bolt holes on the K. It just picks up the car after that.
1991 GT
No idea yet
I wish there was a video of it being done with no motor in the car & stock springs. If I see it done, I can do it. There are plenty of videos, but none have the motor removed and stock springs.
1992 Lx
11.39@119.24
the engine isnt that heavy, get your fattest friend to sit on the k member if youre insisting its making it impossible to do
1991 GT
No idea yet
Based off of your profile picture- You're the man for the job. Hahahaa...
At any rate, you seem to be very knowledgeable on the subject- Have you done it exactly this way with the engine out or are you just telling me that it'll work? |
1992 Lx
11.39@119.24
I pulled one of my springs out when I was building my motor to cut a coil, found out you cant cut 4 banger springs, put jack under the a-arm and jacked it back up. Picked the car up a lil, didnt give a shit it worked
1991 GT
No idea yet
4 cyl springs are totally different. Much lighter spring rate.
1992 Lx
11.39@119.24
so have a fat friend stand on the k member
1988 fobra
if you want to add weight buy a couple 50lb sand bags they are pretty cheap but you shouldn't have to i did mine with the motor and trans out i used the 4 hook inner compressor you just have to unbolt everything connected to the a arm to drop it down far enough to get the spring in
89 GT
I've never done engine out spring installation before but I do remember seeing someone asking this same question somewhere once before, and I think someone said they used ratchet straps on either side of the a arm instead of using the jack to compress the spring. I'm talking about the heavy duty tow strap width ratchet straps.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/197485-ive-got-good-one-your-coil-spring-experts.html
| Spring Tool Helps | This thread | Refback | December 30th, 2010 11:05 AM | |
Threads Similar to: I've Got a Good One for your coil spring experts!
| Polyurthane vs. Rubber Isolators (Coil Spring Insulator) | Bangarang | 99-04 | 11 | August 17th, 2010 03:54 PM |
| recomendations on coil over spring rates? | flyin ryan | 5.0 Mustangs | 41 | July 2nd, 2010 09:06 AM |
| Coil Over Experts Chime In! | Stephen4036 | 99-04 | 3 | April 15th, 2010 03:04 PM |
| Need some helping picking coil over spring rate | 99v6stang | V6 Mustangs | 0 | February 21st, 2009 05:40 PM |
| coil spring cutting on 99-04 v6 has it been done | bigpopaz99 | General Tech | 3 | May 18th, 2006 07:37 PM |
