90 GT
Stalling out when going to neutral
So I recently converted from an AOD to a TR3550. Everythings beautiful, except sometimes (not always) when I shift out to neutral, my idle will bounce below 500 and I'll stall out. The rest of the time it goes to about 750 and sits there solid, no movement and everythings perfect.
What should I check? Thanks in advance... -Dennis
Rewarding our friends, punishing our enemies. |
1990 mustang gt
Vacuum leak, iac valve
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
91 Mustang GT
1991 sliver GT
One of my friends had a smilier problem when he put his car in revers it would did. It turned out to be the alternator.
still running the auto ecm?
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
90 GT
Yes... Still using the A9P. However, I have a SCT flash with a year+ old program from AM
The EEC4 uses the VSS signal from the trans to keep the rpm's up (keeps the idle around 1000 above 5mph), this helps prevent stalling during deacell along with other things. I'm not sure how the 3550 or T5 vss functions compared to the AOD with a A9P but you may want to look in that direction.
90 GT
Thanks for the response. I searched on here and on google and found threads of people saying they had to run the wire for the VSS, but no specifics.
Does anyone have the details of what needs to be done? Thanks...
Threads Similar to: Stalling out when going to neutral
| Set my neutral idle to 575? | kotten148 | 2005 - 2010 | 8 | June 2nd, 2010 10:53 PM |
| Car turns off in neutral after WOT | 96SNAKE | 4V / SVT | 73 | January 25th, 2010 04:33 PM |
| neutral switch???? | Frankenstang | 5.0 Mustangs | 3 | September 8th, 2008 02:46 PM |
| Always Make Sure Its In Neutral | B0B | The Clubhouse | 8 | December 19th, 2007 09:04 PM |
| Neutral Into Gear | 98Stang | V6 Mustangs | 14 | October 1st, 2006 10:00 PM |
