what to do???????????
Old December 29th, 2010, 10:47 PM   #1
1987mustanggt's Avatar
1987mustang gt
1987mustanggt is on a distinguished road
ok i need to know what sounds like the best choice????? i was thinking of doing a 351 with twin turbo's but only cause the 351 blocks r cheaper but i heard its heavier and more complicated to install right????OR buy a boss block and stroke it into a 347.. BUT the boss or dart blocks r expensive and im trying to save some money...or should i just leave it as a boss 302 without stroking it....????? i want around 400 to 600rwhp... so can it be done without stroking it?? should i make it a 351???? u guys help me out..?
Old December 29th, 2010, 10:49 PM   #2
1987mustang gt
THE things that i have right now r the turbo's,some headers,all the turbo lines.some msd wiring.and ignition system.mickey tires on the way.and some other small stuff just cant remember right now..
Old December 29th, 2010, 10:52 PM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
How much money are we talking here? And if this is just future fantasy build, please don't waste our time with these questions. There is a million and one ways to get to 400 rwhp, but 600 is lots more expensive. And there is one hell of a difference between the two. So, which do you want and what is your available funds that you have right now.
Old December 29th, 2010, 11:36 PM   #4
1987mustang gt
ok the budget doesnt matter.....the way i want it is with trickflow heads a tremec tko600 trans and all the other goodies i need..i know imma spend around 7,000 to 8k but the more i can save the better... and its not a fantasy build its the real deal..heres pics of turbos for proof and this my car
Old December 29th, 2010, 11:39 PM   #5
Uber88GT's Avatar
1988 Mustang GT
Uber88GT is on a distinguished road
Figure out your end goal, street/stip...what the headers are actually made for and go from there. What are your plans?
Old December 30th, 2010, 08:57 AM   #6
1987mustang gt
just want something for street that i can use once in a while and the headers came with the turbo's they were on a mustang before they got to me..
Old December 30th, 2010, 09:30 AM   #7
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
your car looked better when it was white.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old December 30th, 2010, 09:42 AM   #8
nolife's Avatar
91GT, 88GT, 02GT
I don't know much about turbos but those things look extremely small?
Old December 30th, 2010, 11:38 AM   #9
ryanw's Avatar
1991 Ford Mustang GT
I liked it better white to. But the new paint job would look good if you had not painted your wheels. just my opinion
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old December 30th, 2010, 12:08 PM   #10
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
Go for the 351.
Old December 30th, 2010, 12:46 PM   #11
Av8tor is on a distinguished road
400-600 is a pretty wide range to be shooting for. You should definately try and narrow your goals down and be a bit more specific with what you want. Those turbos may even be a bit small if your shooting for 600hp. Im guessing they are just 2 of the turbos of a 2.3L turbo mustang, tbird, xr4ti. A friend of mine made just under 400hp with those turbos and a mostly stock 351 just pushing a load of boost through it.
Old December 30th, 2010, 03:32 PM   #12
1987mustang gt
ok fine i want around 500hp..what if i went with trickflow 170cc heads a tremec tko 600 tranny with a 351 and a trickflow intake not sure which one yet. and turn the boost anywhere from 12 to 20 lbs.with idk some 42lb injectors?? where should i be with that?
ohh the turbo's came off a silvia..
Old December 30th, 2010, 08:35 PM   #13
why such small heads? If you are gonna throw down the cash for aftermarket heads, toss on some TFS FAC 190cc heads
[SIGPIC][/SIGPIC]
Old December 30th, 2010, 08:45 PM   #14
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
What adder said. And honestly, with a power adder such as a turbo, you can get a lot of power without serious motor work. Mild H/C/I fox's with a turbo are putting down anywhere from 440-500+ RWHP.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old December 30th, 2010, 08:45 PM   #15
1991 Mustang LX 5.0
At least those on a 351...
Old December 30th, 2010, 09:43 PM   #16
nolife's Avatar
91GT, 88GT, 02GT
Anywhere from 12 to 20 PSI? That is a HUGE difference, night and day and probably about a 300-400 HP difference between them. The larger the engine, the more impact boost has, adding 10 psi to a 2.0 liter 4 cylinder will yield half the power increase that 10 psi more will give a good breathing 5.0. Again, I don't know much about those turbos but you may want to look at the specs on those and see what volumes they support.
Boost is what if left over that did not make it into the engine. The larger the engine, the more air it consumes. That is why smaller engines need more "boost" to get a good airflow and make power and larger engines need less boost to get the same % power increase. In effect, less boost still gets the same air flow increase. Turbos and superchargers are sized with that in mind. A small turbo that can make 20 psi on a smaller engine may only be able to efficiently generate only 7 psi on a larger engine. I pulled those numbers out of my ass but if you just wing it and assume, you may be highly disappointed.
A single correctly sized turbo 302 with good heads (TF/AFR) making 8-10 PSI can easily make over 500 RWHP and probably have over 300 ft/lbs torque at 2000 and at that HP, the stock 5.0 block is on borrowed time. That is why people are asking what your HP or $$ goal is, that is the only way to give decent advice.
Old December 31st, 2010, 01:19 AM   #17
1987mustang gt
well so far u guys have convinced me to get 190's then.with a 351??? yeah i think 500hp is good i just want a fast car for street and maybe strip once in a while.money wise i would like to spend 6 to 7k if more i dont care..labor aint big problem uncles r mechanics..SO should i be good then?
