Check engine light and idle problem
Old December 30th, 2010, 04:21 PM   #1
1988 Mustang GT
Dhl1005 is on a distinguished road
Ive got an 88 5.0 and its been shutting off at idle lately. i know ive got a lifter tapping but i dont think that would cause it. it will idle kind of high untill i tap the gas then it will go down lower and after 10-20 seconds start trying to choke down but if i hit the gas it wont shut off. I also have a check engine light which may be related?
Old December 30th, 2010, 05:30 PM   #2
Will6138's Avatar
1988 GT MAF
Will6138 is on a distinguished road
First thing I'd do is get the codes out of it and go from there.
Old December 30th, 2010, 05:40 PM   #3
selbyvince's Avatar
1991 ford mustang lx 5.0
12.1@114
selbyvince is on a distinguished road
mine was doing something similar after i changed my valve covers (had to pull the upper intake in order to get to them) found i forgot to plug in a vacuum hose... but that wouldnt make the check engine light come on i dont believe.
Old December 30th, 2010, 06:01 PM   #4
1988 Mustang GT
i checked the vaccum lines they are all fine
Old December 30th, 2010, 08:12 PM   #5
fogged306's Avatar
89 GT
This
Old December 31st, 2010, 05:46 PM   #6
Tony Silva's Avatar
1991 convertible GT
Tony Silva is on a distinguished road
how do you pull the codes?
Threads Similar to: Check engine light and idle problem
check engine light GT33 2005 - 2010 11 August 3rd, 2008 02:23 AM
I need help...check engine light need4steed 2005 - 2010 9 May 14th, 2008 12:14 PM
check engine light manny122 V6 Mustangs 7 March 12th, 2008 01:33 PM
Check engine light! RandoGT General Tech 2 July 27th, 2007 04:25 PM
check engine light 02ATIstang 99-04 24 May 22nd, 2007 05:03 PM
