radiator overflow tube broken
Old December 31st, 2010, 06:19 PM   #1
Tony Silva's Avatar
1991 convertible GT
Tony Silva is on a distinguished road
Ok, so the "low coolant" light just lit up on my 91. I checked the basics and found that the little tube in the overflow resivoir has broken off and is sitting on the bottom of the container. To get the tube out I will be unbolting the bottle and flip it upside down to shake out the tube. Anyhow my question is this: can I use any type of tube to replace the broken one? Where the tube is connected onto the cap there is a wire connector and I am assuming this is where the coolant level sensor is located. The tube is pushed up onto this nipple thing that has a metal tab inside it.
Old December 31st, 2010, 06:34 PM   #2
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
Can u go to your local autozone or ect. and extend the piece that broke off? If not i dont see that piece being that expensive.
Old December 31st, 2010, 07:21 PM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
They usually just end up failing. I have always had them unplugged in all my fox's.
Old January 1st, 2011, 05:15 PM   #4
Tony Silva's Avatar
1991 convertible GT
ok. I will disconnect it and if that light on the dash goes off then I will leave it at that. If not then I will extend the hose. thanks all.
Threads Similar to: radiator overflow tube broken
Anyone have a canton overflow with aluminum radiator? dr.gonzo! 5.0 Mustangs 10 August 12th, 2010 07:50 PM
what overflow tank to use with Procharger humbleLX 5.0 Mustangs 3 April 16th, 2008 08:19 PM
Trans overflow mystang0673 99-04 3 September 9th, 2007 09:40 AM
overflow.... lwhitetrash88l V6 Mustangs 23 June 20th, 2007 07:10 PM
Rad Overflow littledog 5.0 Mustangs 4 April 13th, 2007 05:50 PM
