1995 Mustang GT
Rear end pinion seal
Ok so i am pretty sure my pinion seal is leaking. The other day i felt a bad vibration going down the road come to find out the bolts on the driveshaft were very looses, so i tightened them back up and it fixed that problem but i did notice fluid splattered up on the top of the car and on my mufflers almost in like a perfect circle like the driveshaft was flinging it. But anyways i did some research and found out that there is a seal between the yoke and the rest of the differential. How hard is it to change that seal out is it just an unbolt the yoke put the new one in and re-torque, i have heard other people say you need to set the backlash and all this stuff but all i see is a nut that allows access to the seal. Also im missing two driveshaft bolts now, any idea where i can get a couple more?
thanks for the help Ryan |
as for the pinion seal yes you can take out the yoke itself and replace the seal and put it back together. when you take it apart make a mark where the nut is on the yoke so when you put it back together you can tighten it an 1/8th turn tighter than it was to get the pinion preload needed. the missing bolts, im sure you can take one out and go to the local hardware and find 2. if they are not the 12pt head, just buy 4 so you dont have 2 of one head and 2 of another, thats always agrivating
1988 vert - still in progress 2004 F250 |
1995 Mustang GT
Ok well I talked to AAmco earlier and the guy said that if its splattered on the top of the car then it could be the bearing that's in there as well. He said that the bearing only lets a small amount of fluid by and if its letting a lot by then its bad, I also thought that if that bearing went bad then it would make noise..but it doesn't make much noise at all, he said it would be 150 for the seal and around 500 for the seal and bearing. I just hope the bearing isn't bad, what are the chances of the vibration from the loose driveshaft messing the bearing up? I can see it maybe messin up the seal but not the bearing
1995 Mustang GT
I think I may have found the problem, it seems to be leaking from the pinion nut threads, its coming from in there. The res of the differential from the nut back is bone dry, also I think it started leakin when the driveshaft started to seperate from the yoke when the bolts loosened. I read that people had this issue before and they put rtv around the nut, is there any real fix for this because at this point im pretty sure the pinion seal isn't leakin and its comin from that pinion nut
Thanks Guys for the help |
1991 Mustang LX 5.0
Hell, try Rtv sealant. Sounds like a cheap investment. And use locktite on the driveshaft bolts when you reinstall. Notorious for coming loose.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1995 Mustang GT
Ok thanks a lot..does anybody have a diagram of the differential I know that its comin from the pinion nut I just don't see how, I thought the other end of the yoke was sealed so it shouldn't be able to come through the inside..
93 GT
i also have a pinion seal leak, and a bad vibration around 90-100ish. i just learned about mine but need to handle it asap.
1995 Mustang GT
yup, looks like its goin to the shop, had to do my water pump today because it has been leaking out of the weep hole, and it has been a pain in the ass...
1995 Mustang GT
ok well i am still wanting to tear into this thing and havent done it yet, i heard people count the threads on the pinion nut, what are the chances that if i do this i mess something up? If i put it back to where it was, how exact does it have to be?
1995 Mustang GT
also what the hell do i hold the flange with to keep it from moving...??
1992 mustang Lx
13.4@ 106
Briging this one back. I'm about to replace my pinion seal tomorrow. I took the nut off today to try and take the flange off, but that thing was not budging even with a 4 pd mallet.G use a gear puller tomorrow. I have been reading up and am a little unsure if I need to replace the crush sleeve just to replace the pinion seal. Just swapped a tranny so I'm in there already and noticed it has a small amount of fluid coming from the seal area. Do I need to replace the crush sleeve or just pop the seal off and put the new one in and torque it up to specs?
![]() 1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
technically, youre suppose to replace the crush sleeve whenever the flange is removed, since youre also eliminating the preload. but you can get away with reusing it. use some paint or something bright enough, and draw a line across the pinion nut down to the flange. count the turns as you take it off. when you go to reinstall it, count the same number of turns as when you took it off. line up the marks just as they were, then add another 1/8 of a turn. doing so will get the preload to approx the same spot. i did this a few months ago, and havent had an issue since.
'02 Mustang GTm Convertible - N/A Cammed Daily '88 Mustang GTm - 1/4 Mile Build - 750rwhp Project '97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily |
1992 mustang Lx
13.4@ 106
wish I read this a few days ago. I've been struggling with this for three days now. I crushed the original crush sleeve too far. Wasted a new seal. Got another seal and new crush sleeves and cannot crush it for the life of me. I bought a piece of 3/16 inch steel and cut holes in it to bolt to the pinion plate/ yolk and got a breaker bar but still cant turn it. I'm thinking of getting the solid spacer with shims. The only downside I see to that is the seal. Would I just use no seal until I find the proper amount of shims to use? This will be my third seal I buy because my seal puller tears em up a little getting it out. I've read just about everything I can find about this and honestly this is the biggest pain of a job I have ever done. I swapped a tranny in a few hours.... and now I'm on day 3 trying to get this thing done.
1988 Mustang 5.0 LX
12.48@118.27
theres a think behind the pinion bearing called an oil slinger and thats what evenly lubes up the bearing. So when you take the driveshaft off its the companion flange, then the pinion seal then the oil slinger. you can stick a flathead screw driver on the seal and hammer it out. to put in a new one you can use a regular hammer or even a bearing race
1988 Mustang 5.0 LX
12.48@118.27
also mark the position of the pinion nut so you can maintain the bearing preload
Threads Similar to: Rear end pinion seal
| pinion seal... | 99blackgt | 99-04 | 4 | August 3rd, 2009 07:20 AM |
| pinion seal | 07stanggt | 2005 - 2010 | 7 | October 22nd, 2008 01:17 PM |
| Pinion seal is leaking. | White 89 | 5.0 Mustangs | 0 | July 28th, 2008 03:23 PM |
| rear end seal | 01dutchGT | 99-04 | 1 | May 15th, 2008 12:23 PM |
| pinion seal replacement | nathom05 | 99-04 | 7 | August 9th, 2007 10:18 AM |
