Speed Density VS MAF
Old April 17th, 2007, 10:57 AM   #1
Tr1gger is on a distinguished road
I have heard that modding and engine with the speed density set up will actually slow the car down. Any truth behind this? Is the MAF system the best way to go hands down?
Old April 17th, 2007, 11:15 AM   #2
mustangman9550 is on a distinguished road
MAF for sure. Too many mod.s on a speed density setup and you'll wind up with your ride not acting worth a damn. Definitely if you plan on more than just a few simple bolt-ons go ahead and upgrade to MAF.....it'll be worth it.
Old April 17th, 2007, 03:13 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: Speed Density VS MAF
No, that is totally false. You can run into idle problems with aftermarket camshafts if you have a factory Ford speed density system. Alot of aftermarket EFI systems are speed density. If there was an issue with it being worse than mass air systems everyone would be using mass air, which isn't the case.
Old April 17th, 2007, 04:26 PM   #4
HACKGT350 is on a distinguished road
he is right sd and cams dont go together very well. its gunna have a hard time finding the cam idle and the throttle response wont be very good either
Old April 17th, 2007, 08:31 PM   #5
89LX347's Avatar
89LX347 will become famous soon enough
You will need a chip burned for it to run properly. This is the problem with speed density you have to have a chip burned when you do upgrades to it to compensate for most parts that are better than stock.
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old April 17th, 2007, 10:30 PM   #6
ih8chevy is on a distinguished road
sd is a good way to go for people with experience in that area. maf is a little more street friendly.
Old April 17th, 2007, 11:12 PM   #7
are you also on mustangforums.com?
Old April 17th, 2007, 11:24 PM   #8
tim si is on a distinguished road
My dad has a cougar with S.D. ported heads,long tube headers,F-cam,t-5,373 gears.Idles fine and it will Scream.No chip.( stock ecu)Everyone kept telling my brother it wouldnt work but he tried it anyway.I switched it to mass yesterday and it runs no better,but it probably will get better milage now.he was getting 17mpg with S.D.
Threads Similar to: Speed Density VS MAF
Cai for Speed Density Drick 5.0 Mustangs 16 September 19th, 2007 11:20 AM
speed density cam options itsmyfiveoh 5.0 Mustangs 4 May 13th, 2007 06:01 PM
speed density with stage 2 cam dr.gonzo! 5.0 Mustangs 5 March 13th, 2007 07:39 PM
Speed Density or MAF? 8A_Honda 5.0 Mustangs 15 February 6th, 2007 09:04 PM
Speed Density Darrellx14 5.0 Mustangs 4 December 2nd, 2006 09:50 PM
