351w HP CAP..
Im considering swaping my shortblock for a 351w was curious of what the HP capacity would be on the 351 i know the 302 has about a 475-500 max cap was wondering about the 351 block though
its about the same but u can get an older block (like pre-'72) cuz htose got stronger webbing in the block and can stand more HP
[SIGPIC][/SIGPIC] [SIZE="5"][FONT="Arial Black"]OBEY THE FACE![/FONT][/SIZE] Edited By Moderator. Next time will be a ban. |
Newer 351W blocks (after 1977 or so) are weak. Older (1977 and earlier) can handle about 700 if you don't turn them to hard.
I have a 73' 351W, and it's a two bolt main so I am hesistant to make a ton of power with it. Is this something I should be worried about or no?
Is there such a way to strengthen or convert it to a 4 bolt or even 8 bolt? |
#5 | |
only aftermarket blocks are 4 bold mains, Unless you splay the caps, 2 bolt is all your gonna find, and will hold the power just fine
#6 | |
I have a 1974 2 bolt production block and make over 700hp.
Threads Similar to: 351w HP CAP..
| 302 351w | notsoslow50 | 5.0 Mustangs | 6 | July 26th, 2007 12:14 AM |
| 11 Second 351w | drthunder7 | 5.0 Mustangs | 21 | May 27th, 2007 11:06 AM |
| 351w | dragpipe | General Tech | 2 | May 2nd, 2007 07:53 AM |
| 351w | FastBack71 | 94-95 | 6 | February 4th, 2007 03:40 PM |
| 351w ecu? | 5-0stank | 5.0 Mustangs | 6 | January 7th, 2007 01:13 AM |
