code 41 running lean???
Old January 17th, 2011, 03:17 AM   #1
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
okay so today I got a check engine light pop in my dash on my way to a friends house. I parked my car and ran a KOER test and only got code 41
heres the breakdown: new fuel filter, 11 month old BBK walbro 255 lph fuel pump, new ECT, new EGR, new O2 sensors by bosch, new purge solonoid. I'm running an offroad x-pipe and 24 pound injectors with a calibrated 73 mm MAF. manifold pressure is at -20 at idle, timing is at 12 degrees running 91 octane. fuel pressure is unknown (I don't have a fuel pressure tester.)
what do you guys think? I was starting to climb a hill when the MIL lite.
Old January 17th, 2011, 07:05 PM   #2
1988 Mustang 5.0 LX
12.48@118.27
anyone?
Old January 17th, 2011, 08:11 PM   #3
fogged306's Avatar
89 GT
Swap o2 sensors from drivers to passengers. If you get a code 91 then your o2 is shot. If you get the same code then you have something wrong with your connector or your wiring.
You can also try heating the tip of the o2 with a propane torch to see if you can bring it back to life (if you determine that it's bad). Sometimes running rich will coat the o2 with fuel deposits and it won't function anymore.
Old January 18th, 2011, 12:37 AM   #4
1988 Mustang 5.0 LX
12.48@118.27
thanks fogged. strangely the code just randomly went away
Old January 18th, 2011, 03:07 AM   #5
fogged306's Avatar
89 GT
That's usually a sign of the o2 on it's way out from what I've experienced. They sometimes don't just die instantly, they'll throw an intermittent code for a while before they fail completely. If it pops back on there's a good chance the o2 is bad.
Old January 18th, 2011, 01:56 PM   #6
1988 Mustang 5.0 LX
12.48@118.27
I bought bosch O2 sensors. I only hear there sparkplugs are pretty bad, but whats there rep on there O2 sensors?
Old February 16th, 2011, 12:25 PM   #7
1988 Mustang 5.0 LX
12.48@118.27
I only had there O2 sensors for 6 months
Old February 16th, 2011, 02:39 PM   #8
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Here's the way to test oxygen sensors. You'll need a propane torch, DVM, and basic hand tools for removal.
Of course when you remove it you will want to look at the coloration of the tip. Lead, excess carbon, and even antifreeze can contaminate and poison the sensors.
Remove the O2 sensor. Clip the leads of the DVM to the correct leads of the sensor that read oxygen content. I've only done this for 4-pin heated ones, and I don't know if your model has a heating element in it. Bottom line get a wiring diagram and connect to the actual sensor circuit.
With the sensor in the atmosphere, you should be reading 0 volts, which translates to completely lean. Light your torch. Put the sensor tip in the flame. This simulates a completely rich environment, as all oxygen is consumed by combustion. Your DVM reading should quickly spike to 0.9-1V. If it takes an extended time, over a minute or so, or doesn't achieve 0.9V, it's bad and needs to be replaced. Remove it from the flame and it should rapidly return to below 0.1V. If it fails this, it is a bad sensor.
I hope this helps. It's a cheap and easy way to prevent yourself from going out and buying an expensive sensor for no reason.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old February 16th, 2011, 03:13 PM   #9
1988 Mustang 5.0 LX
12.48@118.27
hey thanks man I'ma try that.
Threads Similar to: code 41 running lean???
Car running lean insanechase 99-04 8 August 18th, 2010 06:40 PM
Lean code JASonic 99-04 9 February 22nd, 2009 02:26 PM
car running lean.... need immediate help 99v6stang V6 Mustangs 59 April 29th, 2008 05:15 PM
Running Lean ROUSHME661 V6 Mustangs 22 November 30th, 2007 01:47 PM
A Running Lean Code DUN DUN DUN!!!!!!! 97Cobra 96-98 4 March 6th, 2006 11:06 PM
