What spark plugs do you recomend?
Old January 19th, 2011, 08:35 PM   #1
ggreene is on a distinguished road
I am putting the finishing touches on my motor. Time for some plugs and wires. Not sure what all info you need to make your recomendation so will give some basic info.
world products heads
aprox 10:1 compression
carberated
msd distributor & coil and 6al ignition box
Old February 12th, 2011, 02:38 AM   #2
1990 ford mustang GT
bennyjet846 is on a distinguished road
E3
Old February 12th, 2011, 02:52 AM   #3
Hardon Enflooziast
98FireyGT!'s Avatar
'94 GT Vert
Havn't tried...
98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light
Send a message via MSN to 98FireyGT!
I'm using Bosch platinum ones, some people say not to use em but they've worked fine for me.
Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP
Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines,
Old February 12th, 2011, 04:28 AM   #4
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Autolite
Old February 12th, 2011, 04:54 AM   #5
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
you should contact the manufacturer of your heads, and ask them what to put in them.
and definitly NOT E3's or platinums
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old February 12th, 2011, 05:39 AM   #6
damn it, you sierous? some dude on forum said e3's are really good. and it costed me 6 bucks each. time to look in the garbage can for my old champion plugs....
Old February 12th, 2011, 06:10 AM   #7
E3 plugs are just another rip off invented by the manufacturers. If you dont believe me, look into "Splitfire" plugs. They were held up in a class action lawsuit because of their product.
Spark only jumps from one point. And making the ground strap larger, doesnt increase performance, it actually masks some of the plug, making it possible to have more misfires.
[SIGPIC][/SIGPIC]
Old February 12th, 2011, 06:14 AM   #8
double post
[SIGPIC][/SIGPIC]
Old February 12th, 2011, 06:21 AM   #9
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
Bosch platinum/iridium 4 over here and have worked fine for me. I heard stories about them being bad for mod motors but never from anyone who had a bad thing happen to them. A friend of my cousins girlfriend told her and she told him blah blah blah.
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
Old February 12th, 2011, 06:27 AM   #10
na i believe u. i was changing my exhaust manifold so i thought i might as well change my plugs too. i bought in the hype. and the e3 box looks all pretty and stuff.
Old February 12th, 2011, 06:38 AM   #11
a mod motor, and a 5.0 have COMPLETELY different ignition systems. Your car used platinum plugs stock. and the Iridium tips may work well in YOUR application.
a 5.0 will benefit most from a traditional style resistor spark plug (copper core). Like the Autolite, Motorcraft, or NGK plugs.
[SIGPIC][/SIGPIC]
Old February 12th, 2011, 08:57 AM   #12
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
I have always had issues with the 5.0 and fancy spark plugs. I run motorcraft. The fancy ones seemed to cause problems like timing and miss-fire.
Old February 12th, 2011, 09:25 AM   #13
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
the bosh platnum 4's are pretty short (good for headers) ,and are a side gapped plug. yes the spark travles to only one electrode, but the side gap un-shrouds the flame kernel. i think traditional plugs are fine though. not alot of power found in trick plugs. hey ohsplat am i trippen our is the intake on the motor in your avitar backwards? might have somthing to do with the 15 min 35 mph thing!lol
Old February 12th, 2011, 09:38 AM   #14
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Not E3, and I'm not high on Bosch Platinums for performance. I use Autolite race plugs.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old February 12th, 2011, 12:50 PM   #15
ryanw's Avatar
1991 Ford Mustang GT
LOL i never noticed that, ha ha. If he wants to put that motor in a mercury cougar it would be correct
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 12th, 2011, 01:57 PM   #16
the e3's is a resister type plug just so u guy sknow. but it's called a diamond tipped plug or some shit like that. so i'm ok right?
Old February 12th, 2011, 02:00 PM   #17
Will6138's Avatar
1988 GT MAF
Will6138 is on a distinguished road
Stock motorcraft in mine
Old February 12th, 2011, 02:17 PM   #18
whatever dude. Its not my car. You already spent the money... might as well stick it out.
[SIGPIC][/SIGPIC]
Old February 12th, 2011, 06:00 PM   #19
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
carberated
Autolite or Autolite racing. Use copper core and not platinum. Platinum plugs are for long life, not performance.
That is a fact. Electricity takes the path of least resistance meaning one of the paths will be of least resistance. There will be one spark and only one spark. These companies prey on people that don't know anything about electricity. It is "false advertising" in every way.
Old February 12th, 2011, 08:08 PM   #20
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Autolite or Motorcraft standard style plugs. E3 = Ejunk!
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Threads Similar to: What spark plugs do you recomend?
Spark Plugs Gap for Colder Plugs Matt. V6 Mustangs 5 April 10th, 2010 11:48 AM
Spark Plugs acuboost 2005 - 2010 1 April 7th, 2010 04:48 PM
Oil on the spark plugs? 1997Stang 4V / SVT 17 May 6th, 2009 01:21 PM
Spark Plugs 89LX347 5.0 Mustangs 1 October 9th, 2007 01:10 AM
spark plugs. Ware V6 Mustangs 12 October 3rd, 2007 09:37 AM
