Discussing removing the smog pump in the 5.0 Mustangs Forum. if u taake the smog pump off of a 00-04gt will it set a ...
Old April 19th, 2007, 12:13 AM   #1
if u taake the smog pump off of a 00-04gt will it set a dtc.??? and is it jus as simple as taking the smog pump off of an 89gt
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old April 19th, 2007, 06:34 PM   #2
db83stang's Avatar
are you still running cats? if so you risk destroying them. the air that is pumped to them is to help burn hydrocarbons left in your exhaust with out the extra air they will have a hard time doing so and will eventually clog. and you will probably get a check engine light with catalyst efficency codes. as for the removal of the pump its self i have no idea.
Threads Similar to: removing the smog pump
Removing non-working AC & Smog Project_Stang 5.0 Mustangs 9 September 29th, 2007 11:13 PM
removing smog pump on 87GT marks87gt 5.0 Mustangs 1 April 20th, 2007 04:04 PM
Smog Pump jcc1991 5.0 Mustangs 3 September 4th, 2006 12:51 PM
smog pump cali 5.0 5.0 Mustangs 3 July 24th, 2006 02:03 PM
WTB: Smog Pump cobralini Want to Buy 5 June 4th, 2006 11:58 PM
