Please help car wont start key turns but steering wheel locked
LinkBack (1) Thread Tools
Old January 28th, 2011, 01:20 AM   1 links from elsewhere to this Post. Click to view. #1
firstamericanking is on a distinguished road
Okay so I've replaced the ignition lock cylinder and the starter I turn the key and nothing complete silence. From what I can see and hear power seems to be works fine. I have an idea what it could be but "im not a mechanic so what do i know". The only clues I can give is the keys turns but the steering wheel locked. PLEASE HELP
Old January 28th, 2011, 06:24 AM   #2
fogged306's Avatar
89 GT
Are the ignitions coming on when you turn the key?
Old January 28th, 2011, 06:48 AM   #3
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
if the steering wheel is locked after you turn the key, I would lean towards the lock cylinder being bad. Since you said you replaced it, you either installed it incorrectly, or there is a fault deeper in your steering column.
As for the car not starting. Have you tested for a 12v signal at the wire that activated the starter solenoid? If you have 12v there, the solenoid might be bad.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old January 28th, 2011, 09:34 AM   #4
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
On my car you have to turn the steering wheel a little while turning the key to unlock it. As far as the starter get a test light or voltmeter and check if the starter solenoid is getting and sending 12 volts during crank like he said
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old January 28th, 2011, 10:20 AM   #5
s351r13's Avatar
1996 Saleen S351
s351r13 is on a distinguished road
In addition to this you could also have the wrong ignition lockset. In 95 mid year they went to a different lock set. 94's all used the same one.
96 S351 #13
99 S351 #14
99 S351 #46
94 S351 #35
95 S351 #43
00 S281 #417
02 S281SC #117
Old January 31st, 2011, 10:40 PM   #6
im almost positive the problem is the lock cylinder not sure how i could have installed wrong being so simple (but if it was easy i wouldn't be having problems) but this is the second one ive installed assuming the first was bad ....... would have it towed but the steering wheel being locked is big problem
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/201657-please-help-car-wont-start-key-turns-but-steering-wheel-locked.html
Car Wheel Cylinder This thread Refback January 29th, 2011 05:10 AM
Threads Similar to: Please help car wont start key turns but steering wheel locked
It wont fire up after sitting! but it turns over and over and over :( saber63 V6 Mustangs 24 September 11th, 2010 04:31 PM
93 LX Engine Turns Over But Won't Start - HELP!!! DREDD_LX93 5.0 Mustangs 40 June 8th, 2010 07:03 PM
98 v6 mustang turns over stong has new fuel pump and has spark wont run freehobo85 V6 Mustangs 1 March 7th, 2010 08:35 AM
car turns over but wont turn off 01dutchGT Classic Mustangs 4 October 27th, 2009 09:46 PM
